Serpent 733 1/10 200mm touring
#4186
Hi, since I'm a beginner, would it be better for me to just use this car until serpent comes out with a car to replace the 747 instead of just upgrading my 733 to look like a 747?
#4188
I checked the price and it is around $210? The owner of the shop said the kit cost $520... 5 parts for $210 and a kit for $520.. Didn't really seem like a good deal to upgrade..
#4190
Are you still in Vancouver area . If so come to the RRR track this weekend and we will help guide you with parts for the 733 if you break anything . Three of us are running the kit and the te kit with us looking at the 747 for next year .
We are not doing the upgrade just direct to the new kit .
#4191
Hi!
Just asking ...
Two digital servos, futaba, bls451 for th, and team asso ds1015 for steering.
Futaba is abotu 10kg/0.1sec per 6V, and DS is 14kg/0.1sec/6V.
Now, probably I can do last race this year, but final is 45min.
My life accu is 1450mah.
Under discharge (linear, graupner charger duo 50) 2A to 4.5V from charged, it works 38min.
It is possible do 45min with 2-3min warm up on that accu?
AVG time on lap is 12sec using more full th then breaking
Regards!
michal.
Just asking ...
Regards!
michal.
#4192
Hi,
you should have no problem with time. I have 2 savox 1251 LP and after 45 min final I usually charge about 600-700mAh. I have LiFe 1450.
#4193
Hi!
Just asking ...
Regards!
michal.
Just asking ...
Regards!
michal.
#4196
Ugh!
S733 sucks ...
1st gear always loose on my bumpy truck.
Gear shaft is too low compared to xray, kyosho, shepard ...
in left cornering car lean some and they always touch ground ...
not going more with 733/744
I can sell my 733 with all spares for 100 euro + shipping.
pm me if want
S733 sucks ...
pm me if want
#4197
Ugh!
S733 sucks ...
pm me if want
S733 sucks ...
pm me if want
#4199
ok. I'm not perfect.
When my right tires go off (left side F/37, R/40, right side F/40, R/42) then car was like this\ so spur always grab ground.
I start from 64rears 61.8 fronts.
Tires goes off that R side was 1-1.5mm smaller on diameter then L side.
Anyway, if I will stay with 733 just for fun, I will move up that gear shaft 1.5mm, just add hand made allu washers.
Regards!
m.
ps: velox ordered.
Regards!
m.
ps: velox ordered.
#4200
Regards!
m.
ps: velox ordered.
Regards!
m.
ps: velox ordered.
