Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! >
Like Tree3Likes
Old 08-27-2007, 08:36 PM
  #796
adamge's Avatar
180 is perfect. Any time I use the throttle with my 4600 and 5700 MM motors in my touring cars I see 170-180. And that's with ambient temps at room temperature. I'm convinced these motors always get that hot when they are being used.
adamge is offline
Old 08-27-2007, 10:45 PM
  #797
Originally Posted by wyd
Can always run offroad at Bumps and Bruises during the winter and keep running your brushless setup. You could run a 6900 or 7700 since traction is so freaking off the charts you can practicing doing wheelies all the time.
Other than the Max being a little large it works great and at least in offroad cars they fit easily. In touring I creative wiring and they fit in most cars. Works well in my MI3.
atleast it fits i got moungt it on an angle in the my ta05
C_Suzuki is offline
Old 08-29-2007, 05:24 PM
  #798
Look at this picture on Repair Invoice from CC,
and CRASH said.
Originally Posted by CRASH
Yes, Joe works for Castle. New version of tech and he has not updated his signature.
If he told you to cut off the connectors and direct solder then no it should not void your warranty.
As for the shaft breaking yes that should be under warranty as well.
Call Joe direct at 913-390-6939 Ext 119
Later,
I solder all of my motors directly to the ESC. I run touring car so this makes it easy. For offroad just solder the wires together and heat shrink. A little bit more trouble but in the long run you will be much happier.
Later,
Kidding? I have a stutter problem. How can I do???
Attached Thumbnails Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-_131.jpg
xtaiji is offline
Old 08-29-2007, 08:31 PM
  #799
Alltapdout's Avatar
Just un-soldier the gold plated connectors that are supplied with the esc. And re-soldier the wires togeather. That will not void warranty I was told.
Alltapdout is offline
Old 08-29-2007, 08:47 PM
  #800
Mike Haynes's Avatar
Originally Posted by C_Suzuki
do you run high power brushed mode or standard?
I just started to run the MM for brushed racing recently, and can honestly say that it has been off to a good start...
Mike Haynes is offline
Old 08-29-2007, 08:59 PM
  #801
Island Losi's Avatar
so its offical that if u direct solder or cut the orginal esc wires to make it short and neat u will void the warrenty?
Island Losi is offline
Old 08-30-2007, 04:42 AM
  #802
Therefore, I can't do these???
I found all from this thread.
Attached Thumbnails Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-bl1.jpg   Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-dscn1148.jpg   Castle Creations Mamba/MM/MMM FACTORY Q&A thread!-wiring.jpg
xtaiji is offline
Old 08-30-2007, 05:05 AM
  #803
CRASH's Avatar
Trader Rating: 26 (100%+)
It is my understanding that removing the plugs, shortening the wires and directly soldering the wires together does not void the warranty.
But removal of the wires from the esc circuit board itself and re-soldering of wires to it does void the warranty.
Please stay tuned for a official response from Joe Ford.
Later,
CRASH is offline
Old 08-30-2007, 07:37 AM
  #804
Joe Ford's Avatar
You CAN remove the gold connectors and solder the wires directly together WITHIN warranty. ANY soldering done on the controller itself VOIDS THE WARRANTY.
Joe Ford
Product Specialist
Castle Creations
Joe Ford is offline
Old 08-30-2007, 08:08 AM
  #805
Bernie Wolfard's Avatar
Default What Joe Said
Joe has posted our warranty policy.
Bernie Wolfard is offline
Old 08-30-2007, 08:53 AM
  #806
wyd
wyd's Avatar
Trader Rating: 51 (100%+)
Nice!!!!!!!!!!!!!!
wyd is offline
Old 08-30-2007, 08:58 AM
  #807
barber's Avatar
trying to contact joe check your pm
barber is offline
Old 08-30-2007, 09:41 AM
  #808
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
when its time to get those wires changed, do u have to send it in for new wire? eventually i'll need to, when who knows. but its an interestin question. hope no1 would get cute and leave the last 1cm of wire onto the board, then do all their other work via new wire soldered there.
just curious because...
...the receiver line is 'tired' (from being run under the battery channel and out on these 2wd buggies). i'd like to replace it, i'm adept at doin so (childs play compared to converting futaba G speedos to futaba Js that i did as a young man), but if it voids me out....eck thats a spot.
thx
R
UltegraSTI is offline
Old 08-30-2007, 11:08 AM
  #809
wyd
wyd's Avatar
thx
R
I can change them for you with no problems. I have changed all of mine so far and zero issues. You need a very good soldering iron to do it. It is easy if you have someone to heat the wire and the other to keep tension on them til it comes out.
wyd is offline
Old 08-30-2007, 11:12 AM
  #810
Registered User
UltegraSTI's Avatar
hey b, its not that i worry over doin it. its the worry of doin it for normal maintenance and voidin a warranty b/c i like my stuff to be proper.
R
