Like Tree5Likes
SC10 4x4 Thread
Old 09-21-2011 | 01:59 PM
  #7636
BryanAZ's Avatar
Hey ya'll, I've got an interesting problem with my 4x4. This started out of the blue, with the slipper cranked down all the way, it lets the front wheels roll a bit and makes the clicking noise when I hit the brakes. What could be the problem? I checked my belt tension, and even lowered my brake through he radio to soften the braking. This thing used to stop on a dime but now it rolls and the back wheels lock up, sometimes spinning me out. Any thoughts?
BryanAZ is offline
Old 09-21-2011 | 02:05 PM
  #7637
I would say check the clicker setting may have worked loose
cjhoward78 is offline
Old 09-21-2011 | 02:06 PM
  #7638
BryanAZ's Avatar
I did and it is totally tightened down.
BryanAZ is offline
Old 09-21-2011 | 02:10 PM
  #7639
Have u checked the teeth on the clicker it self. Mine truck does click whwen applying brake from full speed for a second but that belt slippage is normal.
Old 09-21-2011 | 02:12 PM
  #7640
CoyoteSlash's Avatar
Then it's stripped out. Take it off and check the teeth for a nice sharp fit, in a good hit, it'll skip no matter what and round the teeth. People have CA'd the thing together saving themselves from waiting for parts when the truck was brandnew.
CoyoteSlash is offline
Old 09-21-2011 | 02:17 PM
  #7641
BryanAZ's Avatar
Good advice, I will check it as soon as I can. If that is the case, do you guys reccommend gluing it or getting a new clicker assembly?
BryanAZ is offline
Old 09-21-2011 | 02:18 PM
  #7642
Depends on if u want to be able to use the clicker
Old 09-21-2011 | 02:20 PM
  #7643
BryanAZ's Avatar
Well, I will glue it for now and buy a new assembly for when I ever want to use it. I like the full time 4 wheel drive, so doubt I will ever run it with the clicker clicking.
BryanAZ is offline
Old 09-21-2011 | 07:20 PM
  #7644
hijinx's Avatar
New tekin pro4 4600kv motor just arrived, clutch basket and new slippers ordered, now just need the truck to turn up.
What pinion spur should I go with the pro4 4600 and tekin RX8?
Cheers
hijinx is offline
Old 09-21-2011 | 07:57 PM
  #7645
Cheers
I have ran both a 14 and 15 tooth pinion and like the 14 tooth better. With this gearing and 80% current limiting the esc came off the track at 122 and the motor at 145. Oh and no one could touch me down the strait. This motor is stupid fast.
Keeferton is offline
Old 09-21-2011 | 08:38 PM
  #7646
hijinx's Avatar
Thanks for that, oh and what size spur is the go?
hijinx is offline
Old 09-21-2011 | 09:38 PM
  #7647
i run the stock 62. Oh and btw the esc temp is without the fan installed.
Old 09-21-2011 | 10:51 PM
  #7648
Originally Posted by Jorge T
Whites are way too soft and the chassis will hit the face of the jump and scrub off speed.
Try yellow in back inside hole on top and inside on arm. Run yellow fronts too. At the sc showdown in Dallas it required skill to not overshoot the doubles and end in the middle of the sweeper.
I wanted to try that today but didn't get a chance. I will get some yellows and give it a try for sure. I also feel my 3800 isnt keeping up with most of the guys at the track. I feel like I am racing a 2wd SC against 8th scale buddies. The other guys stop mid way up the face of a jump and then punch it and double or triple out. I have to hit it with a running go.
slappomatt is offline
Old 09-21-2011 | 11:16 PM
  #7649
TocSin's Avatar
I'm running 13/62 with the 4600 and it's good but feels just a tad under-geared. I may try going up to a 14 or the 60 or 58 spur. Will try the spurs first as the $13 pinions sting the wallet a little.
Absolutely love this motor. Smooth as butter and more predictable than the 1410 I was running before.
TocSin is offline
Old 09-21-2011 | 11:39 PM
  #7650
hijinx's Avatar
Sweet as thanks again
hijinx is offline
