Like Tree5Likes
SC10 4x4 Thread
Old 08-10-2011 | 09:05 PM
  #6046
lcc65's Avatar
Originally Posted by FRONTI3R
Nitro Stampede II Race in Calgary/AB. With some of the best drivers in Canada in attendance along with Richard Saxton from AE, Ty Tessman was able to take the TQ and win in all three classes including 4WD Short Course. In the finals he was able to beat Mark Hughes (AE SC10 4×4) and Patrick Neumann (Team Durango DESC410R) to take a clean win with his Team Associated SC10 4×4.
Ty Tessman please post your SC10 4x4 setup!
Is it me or does Mark Hughes' track width look wider than stock..DE Wheels??
lcc65 is offline
  #6047
ITS ME DAVID's Avatar
You mean 48?
ITS ME DAVID is offline
Old 08-10-2011 | 09:14 PM
  #6048
CoyoteSlash's Avatar
It's the droop and angle. It's the same as the others.
CoyoteSlash is offline
Old 08-10-2011 | 09:17 PM
  #6049
Originally Posted by TPrc
Did I read that right? Is he using the 32p gears on a 540? Is there any advantage to that over the 48p?
The 32p handles the torque shock from the jumps much better than the 48p. So for a high "air-time" track you would want to use 32p, etc. =)
Old 08-10-2011 | 09:29 PM
  #6050
mickeymouse93's Avatar
so i pick one up about a .......2 months ago lol and just going to start building it. and tricks anybody has would be helpful, i mean, as far as doing something special while its being built!
mickeymouse93 is offline
Old 08-10-2011 | 09:38 PM
  #6051
also... putting the novak 550 4.5 in it. any gearing suggestions?
Old 08-10-2011 | 10:02 PM
  #6052
T-BirdJunkie's Avatar
ThunderbirdJunkie is in the midst of stripping his 4w down and noticed his rear arms are bowed in the same manner that the fronts are doing it. Anybody else notice this?
T-BirdJunkie is offline
Old 08-10-2011 | 10:11 PM
  #6053
Aoh
yup, i had the same, i flipped em left to right.
it seems they used too soft of a material for the arms. i hope the FT ver updates it with a stiffer fiber/composite mix
Aoh is offline
Old 08-10-2011 | 10:40 PM
  #6054
Jstall7543's Avatar
See page one.
Jstall7543 is offline
Old 08-11-2011 | 12:31 AM
  #6055
Works great controlling fore & aft flex , easy to install...
125mm Ti Rod
were do you drill the hole in the rear
f1o7x9 is offline
Old 08-11-2011 | 12:37 AM
  #6056
murky123's Avatar
Originally Posted by Rick Hohwart
Ty Tessman's Nitro Stampede Setup is now posted.
also no extra notes on the slipper here, guess he also has no problems with stock slipper setup..
murky123 is offline
Old 08-11-2011 | 01:24 AM
  #6057
Robotech's Avatar
So I get home today and it's like an early Christmas. I went by my LHS and picked up a new servo. The Hitec 865 I found in my toolbox had a tooth missing (hence why it was in my toolbox) and had a dead spot when I turned left. Made for an interesting session last week. So I picked up a new Hitec servo, digital thsi time, and asked if the FT hex hubs where in. To my luck that had arrived earlier today. So I picked them up to. Finally, I checked my mail when I got home and there was my clutch basket. Time to wrench.
The servo is much better and the aluminum hex hubs are a must have (well, maybe not but they're REALLY nice) but the clutch basket...I'm a convert.
I run a 8.5 540. Considering what most here run, 550 4.5s and 5.5s, I thought the 8.5 wouldn't trouble the slipper. Even when I ran the truck for the first time it seemed okay. Seemed to work just fine. Then I noticed I had to sand the slipper some after every two or three packs. If I didn't I could feel the acceleration get soft. I figured with the basket I would be able to get a bit more life out of the pads. So tonight I put it on. One HD pad on the back and one HD pad and one standard pad on the front of the spur. I sat it on my carpet and tested it to make sure it was going to work.
It pulled up the front tires. Now I had heard it doing that with the 5.5s, but my little 8.5 540???? You could see the acceleration marks in the carpet where I got on it. It never did this with the stock unit!!! I'm sold and can't wait to try it on the track. I was going to look at getting a faster motor to clear a couple triples at the track but I'm just going to leave it alone now and see if this change helps. If you think your slipper is fine...doubt it is. This has made me a believer. Thanks Mac.
Robotech is offline
Old 08-11-2011 | 01:29 AM
  #6058
No rear upper shock location, either.
Rick, any plans on releasing a .5* or 1* rear hub or different toe blocks for the 4w SC10?
Old 08-11-2011 | 03:52 AM
  #6059
Mac The Knife's Avatar
Your welcome.
Mac The Knife is offline
Old 08-11-2011 | 06:09 AM
  #6060
I pulled multiple wheelies down the back straight practicing yesterday. I'm running a standard on the back of the spur and 2 HT pads in the basket with an lrp x12 5.5 540. The basket is a great thing
TPrc is offline
