Like Tree5Likes
SC10 4x4 Thread
Old 08-24-2011 | 04:35 AM
  #6796
mrjeremyaaron's Avatar
for those running the clutch basket, did you hve any problems heating the cover to bend out? i cannot seem to get mine bending... resilient plastic much!? the top lip where the belt cover cup mounts is melting completely but still the cover isn't hot enough to bend...
any suggestions?
mrjeremyaaron is offline
Old 08-24-2011 | 04:55 AM
  #6797
daverobbo5's Avatar
Originally Posted by mrjeremyaaron
any suggestions?
the pink B4 buggy wants its daddy! forget that SC whohaaa. when are you coming back to mod buggy ?
daverobbo5 is offline
Old 08-24-2011 | 05:36 AM
  #6798
sparkwraps's Avatar
any suggestions?
I posted what I did on MactheKnife's for sale thread - http://www.rctech.net/forum/r-c-item...ml#post9392323
Worked like a champ and was done with household stuff.
sparkwraps is offline
Old 08-24-2011 | 07:30 AM
  #6799
CraigMBA's Avatar
Are the STRC hexes the same offset as the Teknos?
CraigMBA is offline
Old 08-24-2011 | 09:35 AM
  #6800
1fastslash's Avatar
Hi guys i just got my new o-rings and wanted to be sure i do this right . I am assuming all i do is remove the cartridge and replace the orange X rings with the track star clear o-rings . then i will follow the utube video about building them emulsion style . Am i on the right track here .. Thanks
1fastslash is offline
Old 08-24-2011 | 10:35 AM
  #6801
JayL's Avatar
R/C Tech Elite Member
any suggestions?
I did not bend it. I just dremeled some from the inside until it clears, didn't need much
JayL is offline
Old 08-24-2011 | 10:37 AM
  #6802
Racecrafter's Avatar
You are correct!
Racecrafter is offline
  #6803
New goodies now available for the SC10 4x4 at Track Star from STRC!
Old 08-24-2011 | 10:42 AM
  #6804
mxnickj's Avatar
I might have missed it but has anybody posted a good starting point setup for a bigger outdoor 1/8 scale track??
mxnickj is offline
Old 08-24-2011 | 10:48 AM
  #6805
BlackLabelVinyl's Avatar
Twin shorty pack set up.....
BlackLabelVinyl is offline
Old 08-24-2011 | 10:52 AM
  #6806
1fastslash's Avatar
Originally Posted by Racecrafter
You are correct!
THANKS !!
Old 08-24-2011 | 01:25 PM
  #6807
1fastslash's Avatar
ok guys I have another question . I though I had a loose belt issue so I checked it all out and found the pulleys were wobbly on the bearings and the belt seemed a bit loose so I bought new pulleys and bearings and belt and low an behold its not the belt . I just serviced the diffs last week cleaned em out put new fluid in them and reassembled them the main reason I serviced them was because I thought the noise I heard was a bad tranny gear or something and once I looked at the gears in the front and rear everything looked really good I figured it just has to be the belt well I think I was wrong because if I hold one of the back wheels and goose the throttle it makes a crunching sound from what I believe to be is the rear diff . My question is have any of you had any tranny or diff issues with your truck ? Im alittle upset im going to have to pull the whole back of the truck apart again .lol. I spoke with Chris at AE and he says its probably the idler gear which I wont argue with it just seems like its the diff to me what do you gurus think i value the opinions of you guys and any tid bit of info always helps . thanks
Old 08-24-2011 | 01:52 PM
  #6808
Artikbot's Avatar
Wowzies BLV!
That is a total of 7.6Ah, 7.4V? Or 3.8Ah 7.4V?
I'm very interested on doing this kind of setup, because I refuse to add ballasts to the car, I'd rather use this weight on adding batteries, or useful stuff like that.
I'd rather not adding weight though
Artikbot is offline
Old 08-24-2011 | 01:58 PM
  #6809
ITS ME DAVID's Avatar
Guys I need to swap out my servo that broke is there a easy was to approach this ? Or faster way to swap out the servo
ITS ME DAVID is offline
Old 08-24-2011 | 02:04 PM
  #6810
Finished product!
Totoal of 7.4v and 7600mah.
