SC10 4x4 Thread
My first version on my Chassis Brace I sell guys looked as "po'dunk" as that one. If you sanded off that goop, you'd do your brace some justice. You did well.
I love you.
Yep! That's why I was selling mine at no profit for guys. It's just such a huge difference in performance. It doesn't make you 'faster' persay: It makes the truck 'work'.
I cut one of the outdrive o-rings when changing diff fluid. I think I read on here a couple of weeks ago or so where someone was using a different one that helped out with the oil leaking but I've been unable to find it. If anyone knows of a better option than the AE o-ring I would appreciate it.
Thanks,
Thanks,
Thanks,
Thanks,
Slide in vertical with or without the Sticky peeled. (if you peel to stick them and squish them in, have fun getting them out) I just left the adhesive alone and shoved them in, They are just big enough to stay under VERY hard crashes and with a driver, they pop out.
2 in each Side slot= heavy and as low as it gets without buying a 110.00 Chassis.
http://www3.towerhobbies.com/cgi-bin...&I=LXK204&P=ML
I dig the windshield/hood treatment. Less surface area, less likely to grab air.
I hate the rear fender that end in a sharp corner point that will be the first thing to get torn off/pounded into oblivion.
Well I have not had a body that I did not shoe goo up to help make it last. Other pictures looks like the rear fenders are longer too. I think the fenders have a little down force built in to them.
5Likes
