Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-21-2011 | 08:21 PM
  #1291
houston's Avatar
Tech Prophet
Originally Posted by nitroburnt
Evening guys. I'm running the Nitrotec in an rc8b. Probably not completely broken in yet (a little less than 1 gal). I'm having an issue with a soggy midrange. If I nail it from a stop, it pulls clean, and revs out good. But if I'm rolling on the throttle, like coming out of a sweeper, onto the straight, it sounds really rich, and doesn't RPM well. Low end doesn't seem too rich. If I pinch the fuel line it revs up and wants to stall in about 3 seconds. Again, if I pin it from a stop, everything seems great, it's only when I'm already slightly on throttle and the go to full throttle, sounds blubbery. Temps are around 250 after 10 minutes, smokes a little, but not excessive. Been running Trinity 30%and the Nova #6 plug it came with. Any thoughts? Thanks!
pipe?
houston is offline
Old 07-22-2011 | 03:23 AM
  #1292
jin2803's Avatar
Hi check with u guys , can BTTS use Odonell plug???
jin2803 is offline
Old 07-22-2011 | 03:31 AM
  #1293
Originally Posted by houston
pipe?
Losi RE11. Running on a kind of large, dusty track.
nitroburnt is offline
Old 07-22-2011 | 05:39 AM
  #1294
If doing the pinch test and it's dieing at 3 seconds isn't that alittle lean on the bottom? Could it be a lean bog situation once it hits the mid range?
JoeC is offline
Old 07-22-2011 | 09:38 AM
  #1295
scrapsz's Avatar
Considering going back to Novarossi after two years racing the Ninja JX and OS Speed engines.
Is the only difference between the 21-4 BTTS and BTT the ceramic front bearing? For Mugen 6T truggy...the 2096 pipe with short header providing a stronger bottom yet still sing on top?
Thanks in advance!
scrapsz is offline
Old 07-22-2011 | 01:10 PM
  #1296
houston's Avatar
Tech Prophet
Thanks in advance!
btt and btts difference is the front bearing yes
plus 21-4 (in any form) with 2096ss/41029 will work great in a mugen truck , i prefer more torque like the p5xlt but that personal preference
lmk if you need anything
great truggy combo p5xlt w/17011 front bearing replacement , houston tuned and silicone filled crank and 9853ss/41029 would be my recommendation , the 2096ss is becoming more and more my fav pipe though
ask around and let others feedback tell ya about the combo mentioned
houston is offline
Old 07-22-2011 | 01:13 PM
  #1297
houston's Avatar
Tech Prophet
hate to say it but the re11 is not that good on novarossi engines
many guys have been using the orion 2013 on the nitrotec with great success , the same pipes that are recommended for novarossi engines would be the same for the (novarossi 3 port) nitrotec
houston is offline
  #1298
Has anyone tried the 2096 pipe on a Bonito yet? I just picked up a 2096 to try out but I was wondering if anyone had any feed back on it?
nick64merc is offline
Old 07-22-2011 | 01:18 PM
  #1299
houston's Avatar
Tech Prophet
not on the bonito but yes on the p5xlt , plus 21-4 and a few other novarossi made engines
houston is offline
Old 07-22-2011 | 01:33 PM
  #1300
I was running the 9901/21 combo on it and it was real nice super smooth and great mileage. I am hoping to get a little more performance out of this pipe compared to the 9901. I put the 9901 on my FMS in my buggy. I am going to try it out on the 6th so if no one has a report on the performance of the 2096 I will report back my findings on this setup.
Old 07-22-2011 | 01:35 PM
  #1301
houston's Avatar
Tech Prophet
nice Nick , post it up bro
its a forum and forums are all abpupot sharing and caring
houston is offline
Old 07-22-2011 | 04:01 PM
  #1302
scrapsz's Avatar
Thanks for the feedback, Monty. My only concern with the p5 is fuel economy. I do not have a smooth trigger finger and the P5 can be a fuel hog if you're not butter smooth. I know there's a fine line between having torque and fuel economy. Right now my OS engines get insane fuel economy but I'm searching for some more torque to replace their over abundance of smoothness.
scrapsz is offline
Old 07-22-2011 | 06:31 PM
  #1303
I think it is a little on the lean side on bottom end. I wanted to make SURE I wasn't too rich (low end), causing it to need a too lean top end. I think it's time to try different pipes. This is the only engine I've ran this pipe with, and the only engine I've has this issue with! Thanks for the reply.
Old 07-22-2011 | 06:36 PM
  #1304
Thanks for the input. I've heard good things about the 2013, may be my next investment (investment?). Is this the BEST choice for this engine in a buggy?
Old 07-22-2011 | 07:41 PM
  #1305
houston's Avatar
Tech Prophet
Call me 5035446624
Trust me you can get insane mileage with a p5xlt
houston is offline
