Like Tree3Likes
Tamiya TRF415
Old 06-14-2004 | 09:17 PM
  #2656
JDM_DOHC_SiR's Avatar
Originally posted by rtypec
Dave, I'll post after next weekend's practice. I want to make sure that this setup is "repeatable" and then move forward from there
Sweet.. It will be interesting to find out how your set up is to mine.. Hope your using AE Springs and 3 holes pistions
-Dave
JDM_DOHC_SiR is offline
Old 06-14-2004 | 10:08 PM
  #2657
JimmyMac's Avatar
8 balls at 3mm for the diff.
JimmyMac is offline
Old 06-15-2004 | 08:51 AM
  #2658
rtypec's Avatar
-Dave
Oh no...I'm not, woops 0-2 on that one hehe. Am I supposed to? It seems like the majority of the TRF team was using 3 hole pistons. When one of the Marc's and I were discussing setups and the topic of "how many hole pistons?" came up, he was using 3 and I was on 2 and then we were like, okay so what oil would give them the same feeling and after a few seconds of silent contemplation we came to the conclusion of "bah...just run it" hehehe.
rtypec is offline
Old 06-15-2004 | 11:16 AM
  #2659
V12's Avatar
V12
I think Marc Rheinard always is using the 3 hole pistons and 60 oil. He never changes this regardless of indoor, outdoor or trackconditions. Also he never is using anything other than white/blue springs for rubber indoors and blue/blue outdoors. OK maybe yellow/yellow sometimes for outdoors. This was the same with the EVO3 also. He´s playing around with rollcenters and beside this he just drives the car.
V12 is offline
Old 06-15-2004 | 11:38 AM
  #2660
Holmenkollen's Avatar
At a recent practice for the upcoming Euro`s Marc was using AE gold up front and silver in the rear. He also tested TA white all around. And he had drilled an extra hole in the rear shock tower so the dampers could stand up more vertical.
Holmenkollen is offline
Old 06-15-2004 | 11:42 AM
  #2661
ngo8's Avatar
v12 i guess youre getting ready to watch germanyand holland play
ngo8 is offline
Old 06-15-2004 | 11:54 AM
  #2662
V12's Avatar
V12
Not really. Maybe you don´t believe it but I don´t care for soccer.
I´m a motorsport man.
V12 is offline
Old 06-15-2004 | 12:03 PM
  #2663
V12's Avatar
V12
Maybe he does this at practice. But at the race is a different story.
OK I can´t see everything he´s doing but usually it´s really like this. His father told me indoors he was running the car at 2 races without touching anything.
V12 is offline
Old 06-15-2004 | 12:22 PM
  #2664
He hadn`t touched the car since the Reedy race so I guess he just drove it with the setup that was on it. And he was fast as usual.
Old 06-15-2004 | 02:42 PM
  #2665
Sweet... Looks like I"ll try a different weight oil with the 3 hole pistions and something different springs besides AE Gold & Blue..
-Dave
Old 06-15-2004 | 03:45 PM
  #2666
JimmyMac's Avatar
Kinda reminds me of a Barry Baker setup... he'll change one or two things.. that's about it... That's how I ran my TC3 back in the day... don't touch it or change setup. Worked good where-ever I went... I like those kind of setups.. hehe
JimmyMac is offline
Old 06-16-2004 | 03:25 AM
  #2667
When you find the sweet spot in the 415 or any cars setup all you find yourself changing is ver little things, half a deg of toe on the back or possibly change the rear spring rate. All me and my mate have done in the eurocup this season is run one setup just varying small things from track to track. Rick
Rick Draper is online now
Old 06-16-2004 | 03:27 PM
  #2668
ran the car for the first time today in 19. Man its quicker then i thought. the car has so much rip! I put in the fastest 19t lap in the day but i think i also beat the mods fastest lap. Thing is, i had a bit of a problem keeping the back from skipping out, i was having to be very cautious and turning small amounts, if i over did it, it was gone. any help? setup is
D B D D
-1.5 camber all around
yellow/white
0.5 front toe out
2nd hole frome inside rear
most outer hole on front
6mm ride all around
thanks
Tarnjit
Evo_Uk is offline
Old 06-16-2004 | 03:59 PM
  #2669
JimmyMac's Avatar
I set my EPA on my radio then turn the Dual Rates down to 80-70%. Maybe you can try turning down some Dual Rates. That's the quick way for a sometimes iffy rear end. You could also try to reduce some of the rear droop by .5mm at a time. Or add .5mm shims (at a time) under the rear inner camber link until it goes away. More rear toe in might help as well.
JimmyMac is offline
Old 06-17-2004 | 12:31 AM
  #2670
i also have no shimms under my rear suspension blocks, could that be anything to do with it? its on a good grip high speed track on CS22
Evo_Uk is offline
