Like Tree2Likes
Tamiya TRF415
Old 07-02-2004, 04:05 PM
  #2806
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by V12
JDM_DOHC_SiR
what is included in the kit?
Well the kit comes with EVERYTHING!!
1 set of sus arms
2 sets of front c-hubs 2d & 4d
1 set of rear hubs
1 set of steering knuckles
1 set of 46mm blue alloy dogbones
1 set of 46mm steel dongbones
8 , 950 sized bearings
2 one way drive cups ..seem to be a bit shorter than the normal ones
1 bag of shims
3 sets of tie rod ends
thats about it..
-Dave
JDM_DOHC_SiR is offline
Old 07-02-2004, 04:09 PM
  #2807
V12
V12's Avatar
Dave
Thanks for the information.
V12 is offline
Old 07-02-2004, 04:23 PM
  #2808
Dave
No problem.. I hope to have some pics up in a bit
Old 07-02-2004, 09:26 PM
  #2809
=MisFitz= NuKe's Avatar
Originally posted by Sushi Boy
Hello Rod,
What does flipping the C1 and C2 around actually do? Does it just alter the bumpsteer and ackerman a bit to make it more responsive?
-Korey
Yes, and how do you know which side you put each one on to do what? As in, if I put the C1 block on the left side of the car, will that give tons of steering? Or the other way around.
Thanks,
Mike
=MisFitz= NuKe is offline
Old 07-02-2004, 09:35 PM
  #2810
Turbonium's Avatar
Trader Rating: 27 (100%+)
im not sure which affects which, but i just looked, and 4 of the 5 i run have the C1 on the right... and the one with the C2 on the right is the 414, which seems to have more steering than the 415 or evo at the moment. 'course, it could be totally in the setup! basically, i think it changes the roll center, since the bearing hole is offset, as in closer to one end of the knuckle.
Turbonium is offline
Old 07-02-2004, 09:39 PM
  #2811
Default Edited Set-up sheet
Alright guys, I did this for myself, but figured I would post it on here if you guys might want it. All I did was scan the sheet that comes with the kit, then edit it in photoshop to my liking. You will see the changes, but all I did was take out the Japanese(?) writing so it is easier for me american to find the english words. Then I added in a little section for the aluminum rear hubs, for degree setting, and camber link position. Also moved some things to add a second line in the memo section . Anyways, have at it, and let me know what you think.
-Mike
P.S. It should be the correct size for printing onto a full sheet of paper, but dont hold me to it, because I have not tested printing it yet.
Old 07-02-2004, 09:42 PM
  #2812
hmmm, I just looked and my car has C2 on the left...
Old 07-02-2004, 09:45 PM
  #2813
Turbonium's Avatar
yea, the manual gives that setup. i have swapped them around some. could be maybe why the 414 seems better into corners than the 415... i need to swap on it and recheck tomorrow. ill post what i find without any other changes.
Old 07-02-2004, 09:47 PM
  #2814
Default Re: Edited Set-up sheet
-Mike
Looks nice Mike
-Dave
Old 07-02-2004, 09:49 PM
  #2815
Thanks Dave,
Always nice to have the Master's approval .
Old 07-02-2004, 09:51 PM
  #2816
Ya, I think I may try that also, that along with the other 92,123,521,768,386,734,837,683,728,847,187 things
Old 07-02-2004, 09:52 PM
  #2817
Thanks Dave,
Master far from it but thanks..
Old 07-02-2004, 09:55 PM
  #2818
Turbonium's Avatar
i have been called the master... usually followed with a Baiter...
Old 07-02-2004, 09:56 PM
  #2819
ahahahahah ahahahahahaha.
I just printed it, it fit kinda funky, I will make the propper adjustments and re-post my setup sheet
Old 07-02-2004, 10:08 PM
  #2820
yes please do that
