Kyosho v-one r4!!!! >
Kyosho v-one r4!!!!
Like Tree26Likes
Kyosho v-one r4!!!!
Old 04-24-2011 | 11:35 AM
  #271
GUINT1's Avatar
Originally Posted by speed6
Hey guys, i have a slight issue, the pillow balls where really tight going in the plastic arms both rear and front pairs. So tight that in two of them i couldn't continue half way as it became two hard. I greased them to get things a bit looser but still it didn't help.
So went for plan B: i have this tool that create thread in aluminium (sorry don't know the technical word in English) and used it in the plastic to loosen everything up.
It worked but now its too loose i mean it can get screwed in / out very easily which i believe that with some serious racing some will get unscrewed.
Thought of putting some CA or epoxy in order to create some grip.
What would you suggest
Hey Speed6
I also had this problem when i built my kit.
Once i completed the kit, and now it was time to set the car up.
That is when i found this same problem. But it only happen to me with the rear hubs.
I took a closer look. The rear hubs are made of a different plastic.
And i could not turn the pillow balls in reverse with my huby hand driver.
I removed the lower arms with rear hub still attatched.
I Used my wife hair dryer. (When she wasnt around) lol.
With very little heat to the area, and a L shape
allen key tool which will give you more leverage.
This will help the plastic contract and retract.
Pillow ball should loosen a bit for adjustment.
Hope this help. But you may have already made the holes
to big useing that tap set.
GUINT1 is offline
Old 04-24-2011 | 11:15 PM
  #272
barg's Avatar
Hey guys. Was wondering where u have your gearbox set? Mine is 5.5 turns out which seems like a lot.......
barg is offline
Old 04-25-2011 | 02:09 AM
  #273
Check for oil coming from the one way bearing of the 1st gear.
speed6 is offline
Old 04-25-2011 | 02:59 PM
  #274
barg's Avatar
No definitely not that. That happened when the car was brand new and it wouldnt change at all then. Car has been run for 3 meetings now. There was also a young r4 driver at our big race last weekend that broke 2 rear diffs. The main crown gear snapped at the pin. Not sure if it was big crashes that caused it or under filled diffs. I havent had any issues yet with mine though.
barg is offline
Old 04-25-2011 | 04:12 PM
  #275
yukiyu's Avatar
I belive that happens because of the diff. being under filled , i've seen it happen , other than that the car behaves and handles very good!!
yukiyu is offline
Old 04-25-2011 | 05:59 PM
  #276
Speedypeterb's Avatar
Default two speed
I think the two speed adjustment can be different depending on our track ,motor and your preference, but I think an earlier post mention that theirs was set a lot looser then the stock set up.
Speedypeterb is offline
Old 04-25-2011 | 06:00 PM
  #277
Default kit
hey Jose hows the build going? you done yet?
Old 04-25-2011 | 06:23 PM
  #278
yukiyu's Avatar
Nope.. not really.. i'm waiting for some parts that i ordered.. greetings my Team mate!!
yukiyu is offline
Old 04-25-2011 | 07:31 PM
  #279
Smile parts
what parts may i ask
Old 04-25-2011 | 07:47 PM
  #280
yukiyu's Avatar
brake pads , cvd's pretty much..
yukiyu is offline
Old 04-25-2011 | 11:24 PM
  #281
1evo RRR Driver's Avatar
Default way to fragile!
I wasnt there, but this weekend we had a club race, one of our kyo drivers car was said to have broken 2 or 3 times.........as of rightnow I think the car is really a dissapointment compared to the RRR...this thread is dead for a new car because theres nothing to talk about....for anyone who has ever owned a RRR, we know that the car simply does not break,almost never, they def need to do a rerun of the plastic material!!!
1evo RRR Driver is offline
Old 04-26-2011 | 04:50 AM
  #282
GREGORY!'s Avatar
i don't think that is the plastic material that make people don't buy this new car.for 600$ there are many cheaper cars that you can buy!a 733 evo for 400$ for example.
it's the first time that i am think to change brand!
GREGORY! is offline
Old 04-26-2011 | 04:59 AM
  #283
alangking_306's Avatar
agree with u bro about the material,but if u said the car is really disapointed i totally disagreed,that car awesome,fast,the gear awesome, i have only problem with servo horn steering i guess i am only one riding R4 at my country malaysia (so sorry if i am wrong)for a mean time,and bro what do u expect for the first time batch it also like a 1:1 car we do need r&r, so if any kind a problem come thats why this thread are here for we to discuss and settle the matter,and i think that kyosho team are read this thread.
and i are newbie in this forum and with kyosho only 1 words to describe [COLOR="Red"]awesome
alangking_306 is offline
Old 04-26-2011 | 04:53 PM
  #284
GMartinez's Avatar
The material used is different than the RRR slightly harder with less give & to say that the RRR does not break is incorrect these days at the speed that is being layed down everything breaks Don't blame the car blame the boards easy to say if you don't wreck
GMartinez is offline
Old 04-26-2011 | 05:48 PM
  #285
Martinez I agree because a amateur like myself broke my rrr many times. Also has this person been breaking his car?
Also I think the price is why people are not buying that car. The price is unbelievable.
Travelg Amateur is offline
