Old 08-17-2011, 03:47 AM   #421
What parts are compatible between the RRR and R4?
For example; am i able to fit R4 bulkheads, arms etc to the RRR?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-23-2011, 01:47 AM   #422
XRAY topdeck/fuel tank
XRAY (capricorn) front diff
SERPENT 733 rear diff
SERPENT shocks
and a crap load of other stuff.. car weighs less than 1300g
Old 08-27-2011, 02:05 AM   #423
prg
Hey lil Jason
Did the serpent 733 diff fit into the r4 bulkheads?
How did you you compensate the 40 tooth 733 diff gearing versus the STD r4 42 tooth
Cheers
Pg
prg is offline   Reply With Quote
Old 08-27-2011, 06:43 AM   #424
Originally Posted by prg View Post
Hey lil Jason
Cheers
Pg
The car in the foto above is not a 4r ... It's a modified RRR....i was also confused , but take a closer look to the pic to figure it out!
Still , 30 pages of thread and no answer from kyosho about the diff gears....we 'play' with rings and spacers to get this to work ...
nickiphorosn is offline   Reply With Quote
Old 08-29-2011, 06:40 AM   #425
stokka's Avatar
Originally Posted by Peppuccio View Post
Hi,
no it is not normal ! The problem is that the top cover is too tight and don't fits on the rear diff crankcase. Isn't easy for me to explain in english what you have to do but I try: you must reduce the tooth of the internal diameter of the top cover untill the two parts (diff crankcase and cover) fits exactly. After you have done so you will be able to assemble the diff with oil and gears.
This advice seems to hold the answer to the diff problems + add shim to outside cover to remove play from diff joint. At least I have had 5 days at the track without problems.
If everything seems under control, you're just not going fast enough. - Mario Andretti
stokka is offline   Reply With Quote
Old 08-29-2011, 08:53 PM   #426
Hey lil Jason
Cheers
Pg
I used a xray belt instead, as its slightly smaller.
other than that, if the bearing size on the R4 diff are the same as the RRR, i don't see why it wouldn't fit?
on the RRR it just needed abit of dremeling.
I originally had a capricorn/xray diff in the rear.
Old 08-30-2011, 03:46 PM   #427
that's why i talk about "play with shims and such stuff".....we have never made a discussion about the car set up , the roll centers , all the new stuff , this car has to try it out.....nothing...we only talk about how to get this car to end a race without a problem and we count how many times its of us have run the car withiut a diff problem...."the one has 2 races without a problem , the other one 3 , a frienf of the first guy 1 , ets...."...take a look at the RRR thread.....none made a complaint ever!!!....anyway we support Kyosho , we trust Kyosho and hope for better days in the future...there are almost some new kyosho hopups that overcomes some newbe problems...."hope ends last" we say , so hope!!!
Old 08-30-2011, 04:41 PM   #428
R4 DAIREI DLS. full rear end hop ups
Ghett0 is offline   Reply With Quote
Old 09-02-2011, 06:35 AM   #429
rc-goods's Avatar
Nice....
rc-goods is offline   Reply With Quote
Old 09-05-2011, 11:22 PM   #430
nikoskar's Avatar
Happy news for R4 Owners. Kyosho on September will release steel diff gear and aluminium case cap (rear)
VZW412
and Steel Diff. Bevel Gear VZW417
Source: Kyosho
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 09-09-2011, 05:52 AM   #431
prg
Woohoo now that's great news..
Old 09-09-2011, 09:56 AM   #432
can't wait !!!!!!!
speed6 is offline   Reply With Quote
Old 09-09-2011, 10:03 AM   #433
Nice how can we purchase the following hop ups??
Also your 2 speed housing looks drilled is that a mod?
Old 09-12-2011, 06:01 PM   #434
Location: Beneath a rock down by the river. Don't have money for van
Is anyone using RRR's rear diff on the R4 while the new parts aren't released?
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 09-12-2011, 09:32 PM   #435
Default R-4
Is anybody using a different fuel tank, or a different lid for the tank. The reason why I asked is the stock lid doesn't seal correctly. Please let me know.
Kyosho America, Peak Racing, Kopropo, Gonzo Paintworx, Prime Racing Fuel, Team Trinity, Novarossi Engines.
jeff B is offline   Reply With Quote
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
