Old 09-16-2011, 04:49 AM   #436
peteR4's Avatar
Cool
Originally Posted by jeff B View Post
Is anybody using a different fuel tank, or a different lid for the tank. The reason why I asked is the stock lid doesn't seal correctly. Please let me know.
I haven't problem with the tank. It works right. It does not close tight but it seals perfect.
Anybody knows race results from shimo at Japan national championship with R4? Car is faster from rrr or we need a lot of optional and upgrades to make it go faster?
Capricorn C02 WC , Sanwa M11 , Capricorn engine , Capricorn tyres
peteR4 is offline   Reply With Quote
Old 09-16-2011, 04:21 PM   #437
We begin with ....
VZW 403, 404, 405, 406........u.p to VZW 417. ....nothing else!
Anyway, the car will absolutely run better from rrr....but it needs time !
We will try some of the new optionals the weekend 24-25 of September.
Hope to have the steel diff gears before the 9th of october
....the car is not slow....but itcs not that fast either so as to make the difference...
I m sure that itcs a matter of set up....we will absolutely fond the way to victory again!
nickiphorosn is offline   Reply With Quote
Old 09-18-2011, 02:39 AM   #438
nikoskar's Avatar
Greek Kyosho R4 owners are happy. (most of them )
We arrived almost every optional part for R4 till now. (Waiting aluminum diff gasket and steel gear)
If you want to check them with part numbers and images click here.
Practive pending in order to see what should we expect from them.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 09-19-2011, 01:47 PM   #439
Default Rear Roll Center
Hey people
it seems that you can't alter the rear rollcenter from the rear lower arms anymore!!!! am i right?
speed6 is offline   Reply With Quote
Old 09-19-2011, 04:28 PM   #440
Originally Posted by speed6 View Post
Hey people
Vzw 409...
Old 09-19-2011, 05:01 PM   #441
Seisick's Avatar
1.Keisuke Fukuda 124L. 40.09
2.Keen V Vejrak 123. 40.11
3.Shinnosuke Yokoyama121. 40.03
4.Takehiro Terauchi TQ
5.Takaaki Shimo
6.Yuya Sahashi
7.Toshiyuki Iwamoto
8.Takumi Matsuda
9.Takahata
10.Tadahiko Sahashi
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-20-2011, 05:14 AM   #442
Originally Posted by nickiphorosn View Post
Vzw 409...
That will only lower the roll center i want to raise a bit the roll center.
Old 09-20-2011, 07:26 AM   #443
RC MARKET's Avatar
Kyosho New Shock Spring
Kyosho v-one r4!!!!-ky-vzw414-32516.jpg   Kyosho v-one r4!!!!-ky-vzw415-4016.jpg   Kyosho v-one r4!!!!-ky-vzw415-5017.jpg
RC MARKET is offline   Reply With Quote
Old 09-20-2011, 08:03 AM   #444
What is the difference between stock shocks?
Old 09-20-2011, 11:02 AM   #445
nikoskar's Avatar
Harder with less or more stiffness effect.
www.rc-world.gr
Old 09-20-2011, 12:47 PM   #446
If you use vzw 409 on its upper hole position , this will decrease on throttle steering and will increase weght transfer to the front of the car and generally this will make the car more responsive but with less grip at the rear.....
Old 09-20-2011, 12:48 PM   #447
5.Takaaki Shimo
6.Yuya Sahashi
7.Toshiyuki Iwamoto
8.Takumi Matsuda
9.Takahata
10.Tadahiko Sahashi
Anyone has any link for photos of the jmrca , or a shimo video , or sth????
Old 09-23-2011, 03:38 AM   #448
peteR4's Avatar
Hey nikiphoros.
Shimo was so fast...faster from any camera...
So no one managed to take him a photo...or record him in a video camera...
Old 09-23-2011, 04:11 AM   #449
Hey nikiphoros.
very very funny!!!!i still lough!!!..mpou xa xaxa....
Old 09-24-2011, 02:28 AM   #450
Just finished building the diffs to go into my RRR, and to be honest any seasoned builder should have noticed the problem in building the rear diff, there is way too much play!!! I was noticing probably at least a full 1mm of play between the outdrive and case on the gear side of the diff, all I did was shimmed on the interior but also the exterior of the diff case so that the gears mesh with only a small amount of forward and aft play, to much one way and the gears will strip and then to much the other and the gears will become too tight and simply split, the proof will be in the pudding so we'll wait and see when I fire the beast up, the front diff looks the part in the RRR, just used some custom inserts to fit the original RRR bearings to the R4 Case.
Now does anyone have an oil thickness comparison between the RRR diffs and the R4 diffs.
B.C.Ninja is offline   Reply With Quote
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
