Kyosho v-one r4!!!!
#271
Hey guys, i have a slight issue, the pillow balls where really tight going in the plastic arms both rear and front pairs. So tight that in two of them i couldn't continue half way as it became two hard. I greased them to get things a bit looser but still it didn't help.
So went for plan B: i have this tool that create thread in aluminium (sorry don't know the technical word in English) and used it in the plastic to loosen everything up.
It worked but now its too loose
i mean it can get screwed in / out very easily which i believe that with some serious racing some will get unscrewed.
Thought of putting some CA or epoxy in order to create some grip.
What would you suggest
i mean it can get screwed in / out very easily which i believe that with some serious racing some will get unscrewed.Thought of putting some CA or epoxy in order to create some grip.
I also had this problem when i built my kit.
Once i completed the kit, and now it was time to set the car up.
That is when i found this same problem. But it only happen to me with the rear hubs.
I took a closer look. The rear hubs are made of a different plastic.
And i could not turn the pillow balls in reverse with my huby hand driver.
I removed the lower arms with rear hub still attatched.
I Used my wife hair dryer. (When she wasnt around) lol.
With very little heat to the area, and a L shape
allen key tool which will give you more leverage.
This will help the plastic contract and retract.
Pillow ball should loosen a bit for adjustment.
Hope this help. But you may have already made the holes
to big useing that tap set.
#274
No definitely not that. That happened when the car was brand new and it wouldnt change at all then. Car has been run for 3 meetings now. There was also a young r4 driver at our big race last weekend that broke 2 rear diffs. The main crown gear snapped at the pin. Not sure if it was big crashes that caused it or under filled diffs. I havent had any issues yet with mine though.
#275
#276
I think the two speed adjustment can be different depending on our track ,motor and your preference, but I think an earlier post mention that theirs was set a lot looser then the stock set up.
#277
#281
I wasnt there, but this weekend we had a club race, one of our kyo drivers car was said to have broken 2 or 3 times.........as of rightnow I think the car is really a dissapointment compared to the RRR...this thread is dead for a new car because theres nothing to talk about....for anyone who has ever owned a RRR, we know that the car simply does not break,almost never, they def need to do a rerun of the plastic material!!!
#282
i don't think that is the plastic material that make people don't buy this new car.for 600$ there are many cheaper cars that you can buy!a 733 evo for 400$ for example.
it's the first time that i am think to change brand!
#283
and i are newbie in this forum and with kyosho only 1 words to describe [COLOR="Red"]awesome
#284
#285
Also I think the price is why people are not buying that car. The price is unbelievable.
26Likes
