Old 05-01-2011, 01:29 AM   #301
prg
Default Rear diffs
Having problems with the rear diff, the gears don't seam to completely mesh and they just strip out, with the second diff I used 60,000 and made sure it was completely full, it lasted one meeting and stripped out at the end of final
Now not sure what to do, any advice appreciated , Aldo anyone know who has diff parts in stock . Thanks
prg is offline   Reply With Quote
Old 05-01-2011, 06:13 PM   #302
barg's Avatar
Send a message via Yahoo to barg
I blew a rear diff yesterday as well. This is a big worry as the diff was only 2 days old.
Does anyone know how to pass this information back to Kyosho. This issue needs to be fixed sooner rather than later.
I am also after a front locker. Does anyone make an after market for this yet? Someone mentioned using an Xray locker. Is there much modification required to do this?
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 05-01-2011, 11:05 PM   #303
Which one is better the Shimo Edition or the R4?
Kyosho Baby
The Rookie is offline   Reply With Quote
Old 05-02-2011, 12:28 AM   #304
Peppuccio's Avatar
Hardened gears are incoming in few weeks.
Kyosho R4 - Novarossi Flash factory tuned
Peppuccio is offline   Reply With Quote
Old 05-02-2011, 12:41 AM   #305
Trader Rating: 13 (93%+)
You should have bought a capricorn barg
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 05-02-2011, 12:53 AM   #306
barg's Avatar
Good news..... Where did you hear this?
Do you know if they will be bringing out a front spool?
www.nswrcrcc.com
Old 05-02-2011, 02:07 AM   #307
Peppuccio's Avatar
Directly from Kyosho.
At this moment i am using a front spool from Hudy as i have posted in this thread.
Old 05-02-2011, 02:59 AM   #308
This is true!!! Tunedtoys' seller told me the same
Anassagora is offline   Reply With Quote
Old 05-02-2011, 03:09 AM   #309
So guys which one is better the Shimo Edition or the R4? And why?
Kyosho Baby
Old 05-02-2011, 08:26 PM   #310
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default diffs
I just got the kit in today and those gears are little, what i would do until they send out new gears, I would try to put the diff together dry with an xtra .1 mm shim behind each side of the bigger diff gears and see if it binds or still has play, an or remove shim till it is not binding and is not to loose. if it feels good put the silicone in and run it. I will be playing around with the shims tomorrow night and will post results.
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 05-02-2011, 08:34 PM   #311
barg's Avatar
Sounds like a plan Pete. I will try it out when I build a new diff.
I haven`t pulled my broken diff apart yet so not sure what happened to mine. But I did see a couple of weeks ago 2 broken main crown gears snap in half where the pin goes from another R4 driver. Im not sure if shimming would have any effect on this?
www.nswrcrcc.com
Old 05-02-2011, 11:08 PM   #312
i just hope that this problem can be fix ASAP!!!.. looking foward to enjoy my car , not the working on diffs!!
Capricorn America , RC Target , Kosmic Fuel , RPM Hobbies , Express Motorsports , Murnan Modified , BrokeasJokeRacingTeam.
yukiyu is offline   Reply With Quote
Old 05-03-2011, 12:19 AM   #313
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
nobody will answer you rookie cause as of now the car is a piece of @%*!
Ive held 1 and have seen it on the track, it looked pretty good, but nothin to talk about, I personally think from a "bad business point of view" that all we Rseries drivers ever wanted n needed was a better clutch and smaller diffs, n a shit load of innovative mods like capricorn!! kyosho didnt need to make a new car! especially not one that looks like a Team magic car!...........sorry to bash im just disappointed to wait all that time for that, n then the sad part is that none of you who bought it will admit that the car is not better than what you had!!Rookie stick with ur shimo or better yet a Evo 2 with a Capricorn clutch and a NT1 diff mod!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 05-03-2011, 04:00 AM   #314
prg
The R4 certainly is a great car. From someone who has shimos and r4's (for myself and a young son), At our home track we have both turned faster lap times and enjoying fine tuning these new models. Yes they are both experiencing rear diff issues but i wouldn't write them off. I have asked rc-champ to look out for the new upgraded planetary gears and heres hoping this will rectify the only real issue the car has. We took our shimos down to a state title event and with the same engine swapped between both chassis the R4 was consistently quicker and more drivable.
Peter
Old 05-03-2011, 04:30 AM   #315
nikoskar's Avatar
Finally the kit arrives to Greece with a good price. 520 euro
http://www.rc-world.gr/gamersclub-pa...kyosho-vone-r4
I agree that the RRR only needed to replace the clutch and diff with smallers but correct me if i am wrong but Kyosho developers know must more than you and me.
There will be an Evo version or an WC or an Evo WC hope. We just need to wait to see what the World drivers like Shimo are capable to do with this new weapon.
If something isn't good enough will be fix it.
Like serpent, shepherd, Xray all are having upgrades.
Just go in the past and find how many things they've changed.
Kyosho has a very good reputation and all hoping to have it into this car.
Time will tell if it's the reliable tank as RRR was.
www.rc-world.gr
nikoskar is offline   Reply With Quote
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
