Old 04-17-2011, 03:47 PM   #241
GREGORY!'s Avatar
can i use the rear shock tower in a rrr?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 04-17-2011, 05:40 PM   #242
Location: Beneath a rock down by the river. Don't have money for van
Hey buddy!I've seen Bertin and Shimo use a very look alike rear tower at the 2010 WC maybe it was the same.
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 04-17-2011, 06:52 PM   #243
GREGORY!'s Avatar
i want to say,if the 2 bottom holes that secure it in the bulkhead are the same position in r4 too.
Old 04-17-2011, 08:43 PM   #244
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default diffs
Originally Posted by yukiyu View Post
whats wrong with the rear diff??
Okay guys tried to speak to shimo day of big race but he said not today, So i spoke with him today during practice.
Do you have any problems with diff in the r-4?
He said some have but not him, He said you must fill diff case full to top and suggested a stiffer silicon 70,000 or 80,000.
do you have any fuel tank issues,
He said that he had none and look surprized. so no one he knows has had no issues with tank.
fyi he runs his shocks with no rebound at all.
If you want see Shimo's practice body run Ft. Myers come see me at the fort may 13 and 14
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 04-17-2011, 09:51 PM   #245
Default diffs.
That is good to know Peter , i noticed that the shocks get no rebound and they are very high quality !! see you at the fort my friend !!
Yukiyu
Capricorn America , RC Target , Kosmic Fuel , RPM Hobbies , Express Motorsports , Murnan Modified , BrokeasJokeRacingTeam.
yukiyu is offline   Reply With Quote
Old 04-18-2011, 03:31 AM   #246
I bought the R4 shock tower to try it on my RRR Shimo, but the holes didnt fit.
So i used some steel epoxy to fill the holes in R4 ST, then i drilled out new holes that fitted the RRR.
I used the RRR ST as a template when i drilled out the holes in the R4 ST.
It worked out great, som im using the R4 ST on my RRR Shimo now.
Sti2 is offline   Reply With Quote
Old 04-18-2011, 04:56 AM   #247
XSLR8's Avatar
Hi guys,just building my r4 kit now in Australia,just wondering is the 2nd spur gear supposed to wobble and move around on the 2nd shoe set,on the rrr it never moved around this much,is this normal for this car and should be left the way it is?Or have I done something wrong? Cheers in advance.
VBC Racing Australia.....FUTABA AUSTRALIA.....Volante tires.....WTF Fans.....R.A.B Hobbies....President www.serccc.com.au
XSLR8 is offline   Reply With Quote
Old 04-18-2011, 05:40 AM   #248
Peppuccio's Avatar
Default 2nd shoe
Nothing wrong. You have to put a 1,5 mm shim around one-way bearing.
Kyosho R4 - Novarossi Flash factory tuned
Peppuccio is offline   Reply With Quote
Old 04-18-2011, 11:45 AM   #249
we had that problem , also the rear diff. stripping but i think that with the prior posts we can work it out..
Old 04-18-2011, 04:54 PM   #250
barg's Avatar
Send a message via Yahoo to barg
That is normal as the 2nd gear is only running on 1 bearing now. I have run my car for 3 days now with no issues so far.... touch wood.
Where in Oz are you?
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 04-18-2011, 04:59 PM   #251
barg's Avatar
Actually guys just another heads up. I had engine dramas in the final at the serpent cup.
What it ended up being was that the clutch spring nut came totally loose and this made the clutch go soft and caused the engine to overheat and drop the plug.... Engine ruined.
When I checked the nut it was extremely loose and the orange thread lock did not go all the way to the end of the thread.
It is the first time I have ever had this issue with a Kyosho clutch and I have been running them for the last 6 years or so.
I will be checking this against some of my old clutches and replacing if the parts are the same. I think they are.
www.nswrcrcc.com
Old 04-18-2011, 08:25 PM   #252
try a hard spring and a rrr clutch.. and a little bit of locktight
Old 04-18-2011, 08:34 PM   #253
XSLR8's Avatar
I race at Dandenong-Victoria with this club, serccc.com.au And a big thank you for everyone's help might try the shim to make me feel better about the wobble!! Cheers Michael.
Old 04-18-2011, 08:40 PM   #254
Default clutch nut
If you have other flywheel nuts try pre applying thread lock to them and let them dry and they will be ready when use them. sometimes when your clutch is set to loose it will back out, using harder spring will help
Old 04-19-2011, 05:49 AM   #255
Default parts
first shipment of r4 parts have arrived
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
