Old 11-10-2011, 06:16 PM   #571
peteR4's Avatar
car seems to be very fast.
Capricorn C02 WC , Sanwa M11 , Capricorn engine , Capricorn tyres
peteR4 is offline   Reply With Quote
Old 11-11-2011, 06:04 AM   #572
R4 is absolutely faster than the RRR ...many options for set up , not just camber toe roll center , but much more that the new cars should have so as to be competitive , ... if you find the right compination that car with the apropriate hop ups that unfortunately are necessary , R4 is really faster
nickiphorosn is offline   Reply With Quote
Old 11-13-2011, 12:21 PM   #573
This car is much faster and alot more stable than any of the R's i haqve driven and i havent even started to mess with setup as yet
bullie1 is offline   Reply With Quote
Old 11-15-2011, 03:59 PM   #574
LCM
Hello everybody:
Im a bit dissapointed of still reading complains about R4 diffs, because the eal thing is that thats a past matter. Since ive been running the hard cases, ive spente more than 10 L of blend whith the same rear diff, and ive had no issues. I agree that Kyosho made a big mistake whith the first design, but soon or late, theyve solved the problem.
Fot those who wonder if the car is faster than the RRR, i can tell them that at least in Spain (we are 3 Kyosho sponsored drivers), weve beaten all our past track records in every track weve raced at, and at least me, in my hometrack, im 1,5 tenths faster per lap whith the R4. May be R4 is not as relyable as RRR, but concerning the speed, believe me,...is faster.
LCM is offline   Reply With Quote
Old 11-16-2011, 01:21 AM   #575
is it possible to come down to 1550g with the R4?
Radiopost TS401
SebO is offline   Reply With Quote
Old 11-16-2011, 04:10 AM   #576
peteR4's Avatar
I'm trying to go down to 1650... 1550 is imposible. With low profile servo, titanium pivot balls, titanium screws and a light motor you can go close to 1630-1650.
Old 11-16-2011, 05:08 AM   #577
GREGORY!'s Avatar
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 11-16-2011, 05:09 AM   #578
GREGORY!'s Avatar
I'm trying to go down to 1650... 1550 is impossible. With low profile servo, titanium pivot balls, titanium screws and a light motor you can go close to 1630-1650.
what about body and wheels?battery?
Old 11-16-2011, 05:14 AM   #579
peteR4's Avatar
life battery cruiser body and wheels !!with!! foam. 60mm-62mm.
Old 11-16-2011, 05:25 AM   #580
GREGORY!'s Avatar
xm,there is not a lot that you can do to go under 1650gr.
lightweight rear and middle axles?
Old 11-16-2011, 06:29 AM   #581
peteR4's Avatar
R4 have already lightweight front axle. If you put rear light axle maybe have proplem with transmition. Light is easy to brake and cut gears because you make axle softer. 1650 is ok...
Old 11-16-2011, 06:58 AM   #582
GREGORY!'s Avatar
have you see any rear titanium or hollow axle broken?or cause gear problems?
Old 11-16-2011, 07:08 AM   #583
peteR4's Avatar
Gear problems... See mtx5... hollow rear axle... Do you want to have problems for 3 gramms?? I dont want! Before 2 years i had problems with gears because of a titanium rear axle. When i change it problem solved...
Old 11-16-2011, 09:45 AM   #584
GREGORY!'s Avatar
i have a titanium rear axle in my rrr for some years now and 10gr less.i hadn't any problems since now.maybe i am lucky.
Old 11-16-2011, 03:55 PM   #585
barg's Avatar
Send a message via Yahoo to barg
Originally Posted by LCM View Post
Hello everybody:
Are you using the steel crown gears? I bought some recently and they are absolute rubbish. I bought 4 sets at $25 a set and they are only the 2 main crown gears.
Well I ran these at our recent nationals and munched through 4 diffs as they do not mesh properly with the old small bevel gears.
I just got the hard diff cases this week and spent 2 nights trying to build a decent diff. The steel gears just wouldnt work no matter what I tried.
I eventually built the diff with all of the original internals and shimming to get it to be smooth.
I have yet to run the diff yet so I dont know if it will hold up but I have to say after running Kyosho for the last 10 years I am so over the rubbish they have bought out with this car.
If I have diff issues again this weekend I will be selling the lot and moving to a more reliable brand.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
