Team Associated RC8Be Thread
#376
Both motor plates inner or outer bb support needs to be pulled out for pinion change.
The only difference is the plate remains on the motor while the pinion is swapped out. The cam locking shroud covers the access to the pinion set screw.
With a stock mount, you still have to loosen the two socket cap screws.
With ours, a single M4 locking nut is loosen, and the beauty of it, it does not need thread locker each time you do a pinion change.
#377
Hey guys!
Im just about finished with my RC8Be build. Really nice piece, but I've ran into a problem...
I thought I would take the MMM kit from my old Vorza and put it in the RC8, since I've seen some people running MMM in theirs. But the 2200kv motor in the Vorza is bigger than the usual CC 2200kv due to its heatsink, so it doesnt get close enough to the chassis for the engine mount..
Should I get the dremmeln out and go mayhem on it? Or simply get a new motor..?
Also, I havent read the whole thread, so if there's anything important that's been said earlier in the thread, please update me
Best regards,
Limpan
Best regards,
Limpan
#378
Just wondering if any of the guys running the rc8be chassis are having any problems or if it is holding up well? I plan to put the tbone skid on mine to help protect the kickup and rear area. payday is getting near so i am gettin ready to hit the pay now button.
how are the shock towers coming?
thanks
thanks
#379
#380
What wt shock oil has been working well for those that are still running the stock pistons? I just have the 25wt that came with the kit. I see on the setup sheet AE has posted that they're running 30wt up front and 25wt rear, but thats also with the tapered pistons. Im mostly running on smooth medium grip clay track.
#381
You may want to visit our support thread that we opened that have most of the questions answered.
http://www.rctech.net/forum/electric...rt-course.html
#382
#383
also has anyone experienced the rear little screws on the back of the esc tray comming loose and falling out? after every weekend i like to take my whole tray out and clean my car but ive noticed that they dont thread that well when you are reinstalling them they are the 2 little ones at the end of the tray
#384
#389
i got a complete losi system for really cheap when i first converted to ele and i ground a lil on the bottom of the losi heat sink to get it to fit.... but like mentioned, if gearded right there should be no need
thanks though!!
