Team Associated RC8Be Thread >
Old 09-19-2010 | 03:28 PM
  #361
Sadly I've had mine over a month now but finally got to building it this weekend. Still need some tire glue and paint and to sort out the power system. Luckily I'm fortunate enough to have several motor and battery combinations to play with to dial it in for the local track. As it sits now.....
305997 is offline
Old 09-19-2010 | 03:40 PM
  #362
b_recliner's Avatar
Well, Maifield TQed with the RC8Be, but it looks like he dropped in the mains. I think he took fourth at the electric roar nats. Pretty good showing for this vehicle.
b_recliner is offline
Old 09-19-2010 | 04:58 PM
  #363
Michael#81's Avatar
He actually took the win in the mains. Maifield TQ'ed and won 2 of the 3 mains taking the overall and the National Title for Team Associated.
Michael#81 is offline
Old 09-19-2010 | 06:17 PM
  #364
b_recliner's Avatar
Awesome, I'm glad I was mistaken!! I knew he TQed, I don't know what made me think he dropped off in the mains. Now I know for sure when I'm losing a race that it is definitely not the car's fault, it is most assuredly me.
Old 09-19-2010 | 08:40 PM
  #365
BLbound's Avatar
The team was testing out new shock towers and new a-arms at the roar nats...hopefully they will be available soon!
BLbound is offline
Old 09-19-2010 | 10:02 PM
  #366
i have a CC 1800 1512 motor on stock spur and 19t.. is this a good combo for a 10 min run?
i noticed the pickup is a little slow. should a 18T be better?
fuse01 is offline
Old 09-20-2010 | 08:41 AM
  #367
frankthetank's Avatar
Man, I love this buggy...to bad outdoor offroad is done in our area. I'm running on 5s 2 the RX8/1550 truggy motor combo with 46/20 and its the t!ts....now AE just needs to get the tc6 out for the carpet season!
frankthetank is offline
Old 09-20-2010 | 04:26 PM
  #368
Is it common for the front driveline to have some chatter in it while turning under throttle? While "on-throttle" at low speeds I have been experiencing some light chatter in the front CVA's/axles.
TMoose02 is offline
Old 09-20-2010 | 05:53 PM
  #369
b_recliner's Avatar
There is another thread on here that fully explains that chatter, but now I can't seem to locate it for you. Anyway, that chatter is perfectly normal so don't go replacing the parts on your front end one at a time convinced they are the chattering culprit because you'll spend a bunch of cash, and there will still be chatter.
Old 09-20-2010 | 05:58 PM
  #370
Nevermind my last post, found my answer in a search. Apparently AE overlooked the 3 pivot CVD system like the Losi CVD's have. According to a discription on another thread, the two pivot design of the CVD's causes the CVD to accellerate and decellerate 4 times in 1 revolution causing the chatter. I haven't noticed much decrease in handling but was just wondering if others are also experiencing this. Might be an upgrade part for AE to look into.........
TMoose02 is offline
Old 09-21-2010 | 07:16 AM
  #371
Team Grid RC's Avatar
Default new motor mounts
Hi Folks,
We have a post up on our new mounts you may like.
If you are using a Tekin motor, one of our mounts can use all 6 socket cap bolts , and if you are using a Neu/Castle, up to 4 bolts can be used.
http://www.rctech.net/forum/electric...rt-course.html
Attached Thumbnails Team Associated RC8Be Thread-grid-motor-mount-01.jpg   Team Associated RC8Be Thread-grid-motor-mount-02.jpg
Team Grid RC is offline
Old 09-21-2010 | 09:31 AM
  #372
Originally Posted by Team Grid RC
Hi Folks,
So you have to pull the motor out of the car and mount off the motor to change the pinion.
sbenja2003 is offline
Old 09-21-2010 | 09:39 AM
  #373
pvalenti's Avatar
Not necessarily...check out their website. gridrc . com
There is an option for a motor plate that supports the pinion from the rear. Using that option (and it doesn't cost any more by the way) allows you to change the pinions at will IN the car.
Personally...I really LIKE what I'm seeing here. It's very smartly designed and it's cheaper than the Elite RC mount! I'm planning to get one ASAP.
pvalenti is offline
Old 09-21-2010 | 09:52 AM
  #374
Hi Folks,
We have a post up on our new mounts you may like.]
What is the range of pinions that would work with a stock 46t spur and your mount ?
Thank you.
Lazer Guy is offline
Old 09-21-2010 | 10:18 AM
  #375
Thank you.
The outer BB pinion supported mount handles pinions up to 18T, and the inner BB supported mount handles the full range. If you don't use beyond 18T in your gearing set up, the outer BB version provides better support for the motor shaft.
The outer BB version is limited physically by the opening it as to pass through in the mount.
So, if you need the full range, then we suggest the inner BB version.
