Team Associated RC8Be Thread >
Old 02-01-2011 | 12:08 PM
  #1861
117's Avatar
117
Turns out I was missing one of the 3mm screws in the Tekin kit. Nevertheless, they were too short to use with the Grid mount anyway. If you're using a Grid mount, I suggest you go get M3 x 10mm and M4 x 10mm screws and not use the Tekin hardware (except to install the fan).
As for the pinion, I'd just use Hot Bodies, as suggested by Grid and be done with it. That way, if you're using the stock mount and upgrade to the Grid mount later, you can still use your pinions.
117 is offline
Old 02-01-2011 | 12:12 PM
  #1862
GreggW's Avatar
Originally Posted by big greg
i hated the lag my MMM had, say if you spin out a little it will not engage throttle for a sec, (which feels like an eternity when your one turn away from the lead) or you case a jump and it hesitates for a split second, i am much happier with the tekin
I posted in the Grid mount thread. I'm using Castle Mod 1 pinions. They are 12mm thick. Works perfectly.
GreggW is offline
Old 02-01-2011 | 12:18 PM
  #1863
GreggW's Avatar
Thinking about getting a Trex 450
+ YouTube Video
GreggW is offline
Old 02-01-2011 | 12:21 PM
  #1864
117's Avatar
117
How about an RC10B4 instead?
I bought a 6CH RC helicopter a couple of years ago. I couldn't get the hang of it. It sits on the shelf now. It was a nice EFlight heli too. $50+shipping and it's yours. Man, I have too much stuff.
117 is offline
Old 02-01-2011 | 12:23 PM
  #1865
Doug2507's Avatar
I've got the ti-turnbuckle set and just thought tonight that the steering arms will be too short. Right enough the turnbuckles are 42mm which is a good bit shorter than the steel ones. Any advice? And have you guys got them taper in or taper out?
Already got some M4x10 flathead hex for the Grid. Will i need M3 as well then?
Doug2507 is offline
Old 02-01-2011 | 12:25 PM
  #1866
symmetricon's Avatar
+ YouTube Video
I sure hope you know how to fly one if you get one. Heli's do rock though.
symmetricon is offline
Old 02-01-2011 | 12:30 PM
  #1867
GreggW's Avatar
I can't decide Billy. I have too much to choose from. I want an onroad and I want a 1/10 off. But that Heli is sweet.
And hell no, I don't know how to fly one. That's what real flight G5.5 is for.
Btw, what are these castle setups going for used? $225-$250. I've run about 10 packs through it. All 4S
GreggW is offline
Old 02-01-2011 | 12:32 PM
  #1868
117's Avatar
117
Yeah, I should have done that first. I thought about buying that program to teach myself. Bad idea to start on the real thing!!!
As for the RC10B4...I'll make you a great deal!
117 is offline
Old 02-01-2011 | 12:35 PM
  #1869
jmackani's Avatar
Originally Posted by Sarinexia
Oh, and PS -
Every motor I've seen in pics (for Tekin) have had the wires soldered facing rear....
I think... pretty sure though.
Yeah, I was looking over at the RX8 thread and even Ty at tekin posted his wires are not soldered the way the others guys have said in here. His post is at http://www.rctech.net/forum/6493769-post5013.html Blade mentioned back in May his problem was due to wires that were too short. And Ty's conflicting post at http://www.rctech.net/forum/7354781-post7614.html
jmackani is offline
Old 02-01-2011 | 12:45 PM
  #1870
GreggW's Avatar
From the pictures I'm guessing that's at least $400 worth the stuff. I looked for the sale thread but I can never find anything in there. I give up after a page or 2.
GreggW is offline
Old 02-01-2011 | 12:48 PM
  #1871
blade329's Avatar
R/C Tech Elite Member
Yeah, the wires that were too short actually pulled apart the solder within the motor. Randy Pike fixed it up for me at the track. He's the one that pointed out that my wires were soldered in the "wrong" direction, after he saw that the tabs were pulling way. So, it was actually two different problems I had.
blade329 is offline
Old 02-01-2011 | 12:55 PM
  #1872
jmackani's Avatar
+ YouTube Video
I have a buddy that just bought one of those. He is brand new to heli also, but he is sticking to the trainer software for now.
jmackani is offline
Old 02-01-2011 | 01:11 PM
  #1873
Whoohooo just placed an order for 2 sets of ProLine Calibers Mounted on White ProLine V2 dish wheels, for $17 a set!!! yay!
agarabaghi is offline
Old 02-01-2011 | 01:21 PM
  #1874
jasons36's Avatar
I'm hearing some bad stuff here....
Robinson Racing Mod 1 5mm 19T pinion.
Am I hearing right this isn't going to mesh right with a Tekin Motor?
http://www.aprohobbies.com/robinson-...on-p-187.html#
PS - on my lunch break.. hence 5 posts
that pinion will work perfectly for you. i dont have the grid mount so i dont know if its compatible with that particular mount but the Robinson racing pinions dont have a particularly long shank.
jasons36 is offline
Old 02-01-2011 | 01:29 PM
  #1875
117's Avatar
117
Are you going to just gloat or share where you bought them from?
117 is offline
