Team Associated RC8Be Thread
#2011
http://www.amainhobbies.com/product_...-Buggy-Tires-2
Look and feel good. Still waiting for the snow and ice to clear...
#2012
I grabbed these last order I made:
#2013
Those actually look really good. I might get some. I ordered my chassis braces, aluminum wing standoffs and alum shock standoffs from Amain. Took 1 day to get. But the $8 in tax and $7 shipping still bothered me. Tower didn't have the chassis braces in stock. When I ordered my Tekin I got the hot-wire and the correct servo horn tossed in there. And with the discount it was still only $331 shipped.
#2014
Yeah, I bought a set of those aluminum shock stand offs too. Nice product, and not expensive at all:
http://www.amainhobbies.com/product_...Aluminum-RC8-4
Gregg, which servo horn did you buy?
#2015
#2016
#2019
Hey guys i finally received my rc8be that I bought used. I have a question about it tho, the front diff looks like it's leaking oil. Kind of hard to explain but it's coming out where the right cva meets the diff. Is this normal, or should I take it apart and replace the fluid and seals? I'll try to post pics.
#2023
The other solution is to put a different O-ring in (aside from the black one that came with the kit). You can either order another under the part number in the instruction manual and you will get the proper size one (it's clear) or put in a kyosho or Mugen one (from what I understand). I have sanded my casing and hoping this will do it. I'll go for the O-rings next if it's a failure.
Frank
#2024
#2025
It's just recommended to change them out. I sanded mine down and it doesn't leak. I'll be damned if I take it back apart risking a leak to change some seals that aren't leaking.
