Xray NT1
#5537
I will buy it, and I will race the hell out of it lol. You must exercise the demons! I won the last time out with my slightly modified NT1. Imagine what I could do with a limited edition ass kicking machine. It might even come with the light weight diff gears so I can spin the wheels off the slow corners even more lol.
#5539
#5540
If i had to guess.. It looks like a 1mm shim from the T3. So we can all just about bet there will be a WC kit or something to that nature with the rear arms being more narrow. Im curious to know if that is a 2602 pipe on the maxpower motor or something else.
#5543
About the a-arms in the rear. What i also notice is the carbon plate on the top of the car, where the upper-link in the rear is mounted, also has 2mm shims...
Aka, that upper-link must be pointing forward a lot, which i can' tmake up from the pictures...
Also, do i see a red clutch shoe?
A-arms in front are also moved backwords, but the ackerman doesn't seem to be changed, that means a LOT of ackerman...
#5544
The engine is a custom tuned one. So a different carb isn't all that exiting :-)
#5546
I also narrowed the rear arms by 2mm. But if you narrow it down by the whole 2mm, the arms begin to rub with the spurs slightly.
#5547
Yeah im kinda curious to Y xray hasnt posted some BIG BIG pics of the win on there page. The only thing i could come up with is there going to come out with a WC car and show the pics. but very weird to not have something up.
#5549
He has the short wheel base. Its a 1mm shim the shim come with the new front arm (its one of the new upgrades for 2010). The arms will work on all of the kits. The part number is 332111.
#5550
18Likes
you can barely make out the droop screw being forward of where it is stock.
or maybe its a serpent part
