Like Tree6Likes
Old 04-07-2009, 10:55 AM   #4036
DS Motorsport's Avatar
Originally Posted by _cyclops_ View Post
Hi Guys,
I've been running the NT1 for a while now, i like the car a lot. One thing i always have trouble with is the clutch. It just doesn't seem to be ok. Setting it is fine, so it engages pretty good but not as good as i want. This seems to because of some play on the clutch bell and the bearings. Anybody noticed this too, the small bearing in front of the clutch always has some play. How did you guys removed that?
Regards,
Ruben
I changed to a serpent WC clutch It's a perfect fit, a much better clutch which is easy to set up. It's also about 10 grams lighter than the original xray clutch(without any options).
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-07-2009, 11:12 AM   #4037
musti72's Avatar
how about pinions? I heard that serpent pinions are crap... can we use xray ones on them?
musti72 is offline   Reply With Quote
Old 04-07-2009, 02:27 PM   #4038
AddictedToRacin's Avatar
Just use the Capricorn WC-Clutch. It's way better than the original one and also much lighter.
AddictedToRacin is offline   Reply With Quote
Old 04-07-2009, 04:01 PM   #4039
Xray pinion's are a straight fit.
In my opinion the capricorn clutch is way to expensive, it's almost double the price of the serpent clutch.
P1-RC.com
Old 04-07-2009, 07:26 PM   #4040
Originally Posted by grub View Post
gidday jelayne
mate first i would check your bearinngs on the two spead shaft and the bearing in your clutch bell
also check the travel on the throttle servo as to much end play will pull on the carby and move the your gear mesh..
just check to make shore the engine is square to the engine mounts as you can get second gear to mesh up perfectly but end up with to much of a cap on the first gear...
also how old your engine the front bearings not shot is it????
In checking it over after all the suggestions, I realised I am getting some movement when the carby slides for brakes, i have increased the the EPA to reduce the movement but I have gotten to 120 EPA on Brakes and still movement, if I reduce the EPA movement increases
jelayne is offline   Reply With Quote
Old 04-07-2009, 09:17 PM   #4041
NiTrO BoOsTeR's Avatar
i dunno about the NT1 but on the mugen there is a nut thing on the wire from the brake arm to the servo and all u do is tighten it a bit more, also screw the screws in on the brake pads mabey a 1/4 of a turn then try i again.
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 04-08-2009, 01:26 AM   #4042
Send a message via ICQ to _cyclops_
Originally Posted by aussies1129 View Post
bearings have only a limited life span and will vary depending on conditions etc so best bet try some new bearing in your clutch bell front and rear there cheap so its no big deal then check the end of your crank shaft to see if you have any wobble really there should be no wobble at all, I replace engine bearings say every 6 months or so and that will depend on how much run time I do on the engine, finally check your thrust bearing and washers are the right way round. once you have your bearings sorted make sure you setup your clutch with a few washers in front of your tension nut to set your end play and all should be good to go
cheers
Well the thing is, the bearing is new, the clutch housing is new. So it can only be the trust bearing holder. But still, if that's new, there's still some play. I feel the small bearings are just to loose, so what small bearings are you guys using?
_cyclops_ is offline   Reply With Quote
Old 04-08-2009, 03:02 AM   #4043
Default Brake Pads
Hey guys can any-one tell me if the option Kyosho ACRE brake pad is a direct fit on to the NT!,, Thanks. At the moment we run the Exceed option Disc, has anyone else tried this with the Kyosho pada.. Thanks in advance.
warpspeed57 is offline   Reply With Quote
Old 04-08-2009, 09:06 AM   #4044
Don't think they fit.
Try the mugen yellow thingys
Old 04-08-2009, 09:29 AM   #4045
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
Don't fit, don't waste your money.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 04-08-2009, 11:59 AM   #4046
D-nicest's Avatar
The KM Racing brakes have worked excellently for me you may wanna try those...
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 04-08-2009, 12:41 PM   #4047
ToysRUsKid's Avatar
+1
Old 04-08-2009, 12:56 PM   #4048
Did you use those on the XceedRC disk?
Old 04-08-2009, 01:23 PM   #4049
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
-1 for exceed disc lol, brakes don't get / stay hot enough to be consistent
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-08-2009, 02:56 PM   #4050
ToysRUsKid's Avatar
do you mean inconsistent? I thought it was the heat from prolonged braking that caused the fading.
