Serpent 710
#6271
Originally posted by InitialD
I did remember Julius or some team driver (Art Carbonnel) mentioning about it at mytsn. If I'm not wrong, you only use it when the conditions are very bumpy. Else do not use it. The upstop is set just enough to prevent the chassis from bottoming out.
Like what you say, it makes the suspension do weird things. The shocks hit infinity when the upstop screws are met.
BTW, there are no upstop screws on the 710 if anyone is interested. Just the front.
Also about the hudy set up station do you guys recomend moding it , or just moving it around
#6272
Originally posted by rodrigo1508
Never noticed that until now. well I asked mainly because in my r40 I started with a default setup just like haras and he did used them and actualy I felt the handling really good , but never new exactly what impact in handling the upstops did since I did a lot of changes at once when I put them.
But this is what Art Carbonnel has to say about upstops;Travel Stops
One of the biggest things I’ve found that people do wrong with the Impulse, and it’s in the instructions, is to use the rear up-stops on the bottom arm. That’s the worst thing you can do to this car. It just limits the travel of the suspension too much, and instead of using your suspension, you effectively end up driving a pan car. This is especially true when the car leans to one side during cornering. The suspension bottoms out, and the car spins out. I prefer to let the chassis hit the ground, so you can get the full amount of suspension.
Think of it this way – you can use the travel stops to limit the car from moving straight up and straight down, but consider what happens when the car leans, especially if it hits a bump while it’s leaning. In these cases, the travel stops hit the limits way too early, and prevent the suspension from working properly. Even if the chassis hits the ground, the car can still lean somewhat, which it can’t if the travel stops are at their limit. The travel stops take away the ability of the chassis to lean that little bit further in a turn.
p/s: Mark, perhaps you want to add this to the FAQ.
#6274
The latest update of the 710faq from markp27 is now on my website http://www.markanddebbie.net select Serpent 710 from the menu and scroll down to the link on the right of the page easier than trolling back over previous threads.
#6275
Mark I live in Holland near the coast where the weathers sucks bigtime and it's allways cold. I must drive about 1 1/5 hour to get to the nearest track.
Our closest decent lhs is a 2 hour drive so that's why I use onlineshops 'cause I only ride my triumph ( 2 wheels ) and I don't have a license to drive a big car
only small ones though )
#6276
I'm pretty lucky in that respect! Here in Germany there are 4 excellent tracks all within 45 mins of me, but none of which have been driveable uptil now due to snow
My LHS is also 45 mins away and has a good selection of goods - but when I need something quickly I send off my order to holland
#6277
Iam going to try again tonight...
thank you for your explantion, very help full !,
BTW, do you think it is posible to get a -x mm for the end play? is so then what do you do? (dumb question NM)
you also mentioned that a poorly tuned engine will not be responsive. well my engine ... when I try to shut it off by blocking the exhaust , takes forever to die. (more than 10 secs)
does this mean It is too rich and I need to lean it out? then engine (sirrio) was broken in but it is a new engine.
thanks, do you know what are the "stock" neddle setting?
I turned 1.5 turns on the low end and 3 on the main needle.
#6278
Originally posted by Julius
We'll I true them to 63.5 in the rear and 63 in front to start at the moment, and run them to 56mm and that takes about 50 - 55 minutes on our track that is quite abrasive.
I change left to right about halfway, If you don't you're looking at about 45 minutes before the outside get's too small. You could of course reset the ride height and run them a little smaller but That is not something I want to do as it would compromise the objective of the test (finding a setup that works with big and small tires)
#6279
just to let you know there in again
the wannahave of 2004
http://shop.the-border.nl/customer/p...roductid=19603
#6281
Originally posted by markp27
Just received my order from those nice guys at www.the-border.nl - super quick service!!!!!
Here's a pic of my new bits
#6282
or else get some good exercise like what Mark does. Cycle ! I'm sure the Dutch can do that...
#6284
