Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 06-11-2010, 10:44 AM
  #9076
Senna Racing's Avatar
Originally Posted by M-Technic
Not in stock (Ampdraw and Speedtech are also sold out).
try rcmarket
Senna Racing is offline
Old 06-11-2010, 06:03 PM
  #9077
haywood's Avatar
Trader Rating: 49 (100%+)
Default 416x
Anyone running foam tires with this chassis?
haywood is offline
Old 06-11-2010, 06:39 PM
  #9078
Trader Rating: 14 (100%+)
If anyone is interested in a 416x and spares here you go:http://www.rctech.net/forum/r-c-item...6x-spares.html
HEWITT is offline
Old 06-11-2010, 07:21 PM
  #9079
Fred Hubbard's Avatar
Sorry to see you over it so fast Alan. Finish school and stay out of trouble and RC will always be here for ya! Keep in touch kid!
Fred Hubbard is offline
Old 06-14-2010, 10:40 AM
  #9080
syndr0me's Avatar
Trader Rating: 32 (100%+)
So the TOP axle pin holders are a direct fit on the 416. Basically, rather than use a setscrew to hold the cross pin in a CVD, this sleeve slides over it and holds everything together. It eliminates issues with pins coming loose, or setscrews backing out, stripping, etc. The only thing you have to be mindful of is that they increase the diameter of the axle ever so slightly, so you want to be careful none of the screws from your ball studs (or coming through the bottom of the steering block) are too long.
In addition to the reduced maintenance, they seem to free up the CVD's in the front a bit as well.
http://www.amainhobbies.com/product_...der-Titanium-4
syndr0me is offline
Old 06-14-2010, 11:03 AM
  #9081
Trader Rating: 51 (100%+)
Does anyone have the part numbers for the Tamiya blue titanium turnbuckles for the front and rear camber links? Are they the same length too? Thanks in advance.
Apex is offline
Old 06-14-2010, 12:43 PM
  #9082
kentech's Avatar
TRF titanium ones are:
42118 for the camber links (32mm)
42120 for the steering links (42mm)
42122 is the wrench for these.
kentech is offline
Old 06-14-2010, 01:01 PM
  #9083
linger's Avatar
Two thumbs up for the TOP axle pin sleeves. I've been using them since the Reedy Race with great results. Since you no longer use a setscrew, the pin is free to rotate and makes the universal operate smoother.
linger is offline
Old 06-14-2010, 01:12 PM
  #9084
Thank you!!
Apex is offline
Old 06-14-2010, 03:55 PM
  #9085
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Thank you!!
These look interesting too
http://www.smokem-racing.com/Ti_TB.html
RAL is offline
Old 06-15-2010, 05:02 AM
  #9086
M-Technic's Avatar
Trader Rating: 15 (100%+)
How are the sleeves held in place?
M-Technic is offline
Old 06-15-2010, 05:09 AM
  #9087
AdamD's Avatar
TJ, Its a collar that slides over the axle right where the pin goes in. They make them in Ti, and red. Aluminum Axle Pin Collar. They fit snug and they can only slide off one way which is toward the bearing so they can't come off.
AdamD is offline
Old 06-15-2010, 05:10 AM
  #9088
Skitee's Avatar
I was also a little concerned about that, so I just put a little dab of tamiya anti wear grease on the axle before I slid the sleeve over the axle. They haven't moved yet so it works.
Skitee is offline
Old 06-18-2010, 12:21 AM
  #9089
Originally Posted by doriftu
I am referring to this step.
1)What does the instruction meant by 'remove' for derlin direct cup (BL9)?
2)I want to disassemble the spool and having difficulty removing the aluminum coupling (BL10) to start with.
Any help is much appreciated. thanks
where can I buy BL10 in the pictures?
Thank you!
Nasty
Kiznasty is offline
Old 06-18-2010, 12:33 AM
  #9090
Skitee's Avatar
Thank you!
Nasty
Tamiya
http://rcmarket.com.hk/product_info....oducts_id=5506
3Racing
http://rcmarket.com.hk/product_info....oducts_id=7240
Skitee is offline
