Tamiya TRF416 / TRF416WE / TRF416X
#9062
#9065
http://www.rcracer.com/on-road-artic...6x-upgrade-set
This new conversion set from Tamiya enables you to set up your TRF416X to use mainstream high-output LiPo batteries. It uses new 2.25mm lower and 2.0mm carbon fibre upper decks ensure high chassis durability.
Set includes:
2.25mm carbon fibre lower deck x1
Battery mount (3 types)
2.0mm carbon fibre upper deck x1
Aluminium battery post x2
Aluminium spacer x2
Aluminium servo mount x1
3mm aluminium lock nut x2
42182 TRF416X Upgrade Set (Tentative)
Availability: July (worldwide simultaneous release)
Set includes:
Aluminium spacer x2
Boy looks like some serious R&D (ripoff and duplicate) went into this chassis as it looks very similar to Exotek's design?
#9068
has anyone seen the 416x clone version. i saw it on ebay. at first i thought is was an original. i kept reading the description all the way to the bottom until it said CLONE VERSION. whats up with that
#9069
http://www.redrc.net/2010/06/spec-r-...nt-solid-axle/
Looks good! Photon style cups, hopefully they wont round out
#9072
#9074
Third link down. It is pretty thorough, and applies to all cars.
#9075
You can download the Hudy set up book here: http://www.teamxray.com/teamxray/pro...c968db7b7ba06f
