Tamiya TRF416 / TRF416WE / TRF416X
#9047
oops yeah - belts were flipped - I must be going blind. too much @%.;.!
Marc and Victor were running SMC packs with bullet connectors. They were just taping in the packs. I can't remember if those packs had humps underneath. I didn't see anything specifically locking the batteries in place.
#9049
http://www.rcracer.com/on-road-artic...6x-upgrade-set
This new conversion set from Tamiya enables you to set up your TRF416X to use mainstream high-output LiPo batteries. It uses new 2.25mm lower and 2.0mm carbon fibre upper decks ensure high chassis durability.
Set includes:
2.25mm carbon fibre lower deck x1
Battery mount (3 types)
2.0mm carbon fibre upper deck x1
Aluminium battery post x2
Aluminium spacer x2
Aluminium servo mount x1
3mm aluminium lock nut x2
42182 TRF416X Upgrade Set (Tentative)
Availability: July (worldwide simultaneous release)
Set includes:
Aluminium spacer x2
#9050
Set includes:
Aluminium spacer x2
Set includes:
Aluminium spacer x2
dunno where you get your info kentech but it must be pretty good, rc champ know nothing about the upgrade yet
#9052
#9055
#9056
Yeah i have the WE,
I happen to have a 60t spur and a 45t pinion also. although i havnt tried them yet
Did you happen to notice if the pinion was very close to touching the top deck??
Also does anyone know if there is any internal ratio modification for this car (to make it lower?)
Yeah i have the WE,
#9057
does anyone know where i can find marc rheinards setup sheet from the 2008 worlds? The one on petitrc is missing some info
thanks
thanks
#9059
#9060
