Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 05-18-2010, 04:48 PM
  #8896
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by MikeR
They have been testing on both but are now getting ready for outdoor events. Yannick has been doing most of the testing and finished right behind Volker at the German Nats so they are feeling really upbeat now that they've been running the chassis for a few months.
Mike... spacers for split blocks.. .5mm spacers.. make it happen man!
Hebiki is offline
Old 05-18-2010, 04:51 PM
  #8897
cheehtae's Avatar
Trader Rating: 15 (100%+)
anybody got a good set up for 17.5, asphalt low grip.
cheehtae is offline
Old 05-18-2010, 09:10 PM
  #8898
Thanks for the reply Mike. Wish I would have known about this a little sooner. I leave for CA this Friday and there isn't time to get it and install it. Unless Nor-Cal hobbies stocks them then its something I could pick up and install Sunday... Ether way I will pick one up at some point.
Thanks again
Kody is offline
Old 05-18-2010, 09:11 PM
  #8899
+1
Kody is offline
Old 05-18-2010, 09:23 PM
  #8900
geeunit1014's Avatar
Trader Rating: 14 (100%+)
This is what I run. You can go 1.5/2 on camber if your wheel/tire will let you (ie no ring of death). I also changed to white/blue for springs, I like the feel better (more aggressive, I want to try the HPI springs soon). You can also go to 4mm on the front camber link if you want more steering
Droop is 2mm over ride height in the front, 2.5mm over in the rear.
On that note, I cant seem to remember, do we need any different shock ends or spring retainers to run the HPI springs?
File Type: pdf
geeunit1014 is offline
Old 05-18-2010, 09:49 PM
  #8901
CraigM's Avatar
Trader Rating: 34 (100%+)
No, the stock retainers are a little small but they work fine. FYI you haven't marked the droop on your setup sheet
Try the HPI springs, silver front blue rear for low grip
CraigM is offline
Old 05-18-2010, 09:53 PM
  #8902
Thanks and thanks
Old 05-19-2010, 04:05 AM
  #8903
cheehtae's Avatar
OK thanks. I'm going to try HPI springs too.
cheehtae is offline
Old 05-19-2010, 01:53 PM
  #8904
JasonC's Avatar
Trader Rating: 120 (100%+)
JasonC is offline
Old 05-20-2010, 02:41 AM
  #8905
LOSI123's Avatar
Trader Rating: 63 (100%+)
Any one tryed the spec r gear diff in the rear with stock or super stock?
how does it hold up
also on website it says fit 416 & 416X
does it fit 416WE
Cheers
LOSI123 is offline
Old 05-20-2010, 03:05 AM
  #8906
AZ416's Avatar
how does it hold up
does it fit 416WE
Cheers
it will fit the WE
im waiting on feeback from someone who is testing it in mod
AZ416 is offline
Old 05-20-2010, 06:01 AM
  #8907
M-Technic's Avatar
My friend and I will be running the Spec R gear diff tomorrow night, both in stock though. I will report back.
M-Technic is offline
Old 05-20-2010, 06:33 AM
  #8908
LOSI123's Avatar
Originally Posted by AZ416
it will fit the WE
Thanks Adam, keep me posted if you could, cheers
LOSI123 is offline
Old 05-20-2010, 07:02 AM
  #8909
Ty
Ty's Avatar
Trader Rating: 32 (100%+)
Does anyone know if the 416X kit comes with the fluorine coated suspension balls? Thanks.
Ty is offline
Old 05-20-2010, 08:34 AM
  #8910
Stein Tumert's Avatar
Mine did not...
Stein Tumert is offline
