Tamiya TRF416 / TRF416WE / TRF416X
#8296
No need to change lower decks. The holes in the lower deck are the same for both chassis (only the cell slots change). You only need to change the rear bulkheads and rear belt to the X version to move the rear diff backwards.
#8298
just check which spur & pinion brand in use?
#8299
another thing on the suspension mount on the 416. can i use the same when i do conversion to 416X?
#8300
#8301
#8302
#8303
do u know where to download the 416X manual..
i can't find it here.. thanks..
http://www.tamiyausa.com/product/ite...oduct-id=42162
#8304
#8306
i m kinda curious to know, if we have 5mm forward which adds the weight to front wheels. the 416 & the X stays the same place. would it be some issues tamiya found out from such config?
#8308
has anyone tried the 2 joints (Xray ECS style) front axles-swingshaft combination on the 416? there are some available from 3rd party manufacturers. i wanted to try but wondering if they are necessary and how significant will they improve the handling of the car.
so any reviews/opinions will be much appreciated.
thanks
thanks
#8310
When testing the anti roll bar's function, the right arm has more free play and feels softer compared to left side. I have checked and everything measured equally. How do I eliminate the play on one side of the arm?
Also, looking at Jilles tips video, he advised to use 0.75mm shim at the suspension block shafts. Where to get that 0.75mm shim/spacer?
Thanks!
Thanks!
