Tamiya TRF416 / TRF416WE / TRF416X
#9826
I know it has been a couple of weeks, but I wanted to post my setup from IIC. The car was really good all week and I think it may be a good starting setup for decent traction on carpet.
I ran the TRF 416X with the new Lipo Chassis...
http://www.projectgreenracing.com/PG...%202010%20.pdf
#9827
Friends, there is some rear tray of some other car that I can use to get the new order? Perhaps the tray TA05 or TA04 or even ZERO SAKURA, someone knows something?
THIS PIECE: 53928, in manual TRF416WE
#9830
I've searched as best as I possibly can...but I can't find an answer.
If I purchase the Tamiya Porsche GT3 body will it fit a TRF416?
I'd like to run a realistic Porsche body.
Thanks in advance,
Brett
Thanks in advance,
Brett
#9831
wheelbase is same, body mounts are adjustable, no issues fitting the body.
#9832
Suspended
Thanks in advance,
Brett
Thanks in advance,
Brett
Find a way to add wide rear wheels and tires in the rear, or configure/ MOD it up somehow to reach a 210mm rear track length
#9833
so what gear fluid is everyone using on asphalt with good traction
#9836
Hey guys, I noticed that there is very little material to mount the electronics on the chassis of the 416. Is there a plate or something to cover the area? Looks like there is a hole to mount something? Sorry never had or seen a higher end Tamiya. Just wondering where you can use servo tape to hold things down. Thanks.
#9837
#9838
Hi,
I also have the same question before , after I use a good tape (ex : 3M tape) no more issue.
#9839
Suspended
come someone please apply some tape to my keyboard so i cannot use it any more! the last time i used double stick tape my hand was stuck to the table.....
#9840
It's small, is it an issue or can you put it closer to the center line and have enough room? Same thing was done on a TC4 was it not? Yeah they used fans and didn't work well. Would be nice to see the holes for lipos on both sides for equal side to side flex instead.
