SC10 Thread
Old 06-08-2010 | 05:48 AM
  #4351
For my next upgrade I am looking at the MIP C-CVD kit.
Any Feedback on this kit?
Thanks!
Eagletal88 is offline
Old 06-08-2010 | 06:03 AM
  #4352
ShortCourseOnly's Avatar
Thanks!
I beleive this is the one in the FT kit. I have them and they have been flawless in the Stock SCT class. I'm running 17.5 so not so much power but not issues. Make sure you get the new ones with the clip retainer. The older ones would loosen up and the pin would slip out and tear up your a-arms.
ShortCourseOnly is offline
Old 06-08-2010 | 06:07 AM
  #4353
T-BirdJunkie's Avatar
ThunderbirdJunkie is running old-style T4 CVDs.
As every other old set of MIP CVDs he has run, they've been awesome.
T-BirdJunkie is offline
Old 06-08-2010 | 01:53 PM
  #4354
Mr.Maim's Avatar
Dude, why do you keep referring to yourself in the third person? It's cracking me up.
Mr.Maim is offline
Old 06-08-2010 | 01:57 PM
  #4355
Mr.Maim's Avatar
No, the wheels THEMSELVES don't spin true. Has nothing to do with the tires.
Originally Posted by Markah
Why not pick up the bead-locs? They seem pretty sturdy unless your truck is just way too bad. They're also very easy to build/rebuild.
May do just that... Anybody besides PL to look at?
OK just said screw it, and bought the PL beadlocks.
Stupid LHS doesn't have them in stock, and they want 25 bucks each pair for 'em and 35 bucks for the body.
Just so you know, if you buy ProLine beadlock wheels you have to use ProLine tires... well, at the very least you cannot use JConcepts tires on ProLine beadlock wheels unless you cut out all the sidewall strengthening ribs from the inside of the JConcepts tires. I was going to go the beadlock route too, but cannot because of my tire choice. I brought a set of tires to my LHS and tried to fit them on the ProLine beadlocks prior to purhcase. No fit. No purchase.
Has anyone had results different than mine?
Mr.Maim is offline
Old 06-08-2010 | 02:04 PM
  #4356
Thanks!
buy the kit for the T4 that is does not have the C before the CVD like this. "C-CVD" http://www.amainhobbies.com/product_...C-CVD-Kit-SC10
Reason:
they use a retainer ring to capture the pin that holds the pivot assembly together. and are VERY easy to break or strip. A fix for those that already have this type of CVD, take some heat shrink and replace the redor white retainer for heatshrink or if you still have the retainer use the shrink tube on top to hold it in place.
Otherwise just save yourself the hassle and DO NOT buy them to begin with.
go for the regular CVD kit as shown here.
http://www.amainhobbies.com/product_...omplete-Set-T4
But as far as the upgrade to CVD's is concerned......WORTH THE MONEY!! i wouldnt run anything less!!!
Pimpin is offline
Old 06-08-2010 | 02:08 PM
  #4357
all you need to do is use red thread lock on the set screw and it will NEVER come out.....much better than those dumb rings.
Pimpin is offline
Old 06-08-2010 | 02:11 PM
  #4358
Mr.Maim's Avatar
Reason:
Good tip! Thanks! (even though I wasn't the one that asked)
Mr.Maim is offline
Old 06-08-2010 | 02:17 PM
  #4359
Mr.Maim's Avatar
Yikes! Red thread lock? You're right about it NEVER coming out.
I put red thread lock on something once. Then needed to get it off. Broke two tool tips before having to Dremel the part off. Never again.
Mr.Maim is offline
Old 06-08-2010 | 02:19 PM
  #4360
You need to heat the area to break the red Loctite. Just hit it with a propane torch for a moment, then turn the screw.
ben
armourbl is offline
Old 06-08-2010 | 02:20 PM
  #4361
Mr.Maim's Avatar
Okay, so I'm getting a little tired of all the short course truck bodies and just want something a little different for a few races at the club. Is anyone aware of any other bodies (rally, bug, truck, whatever...) that fit the SC10?
Just curious.
Mr.Maim is offline
Old 06-08-2010 | 03:06 PM
  #4362
Zerodefect's Avatar
Your supposed to use heat to remove red locktite. A soldering iron or heatgun should do the trick. I use red permatex threadlock alot, red Surelock if there is a gap between the parts that are being put together.
I made a custom body by pulling the stuffing out of a giant stuffed Skunk toy and stretching it over an old Jconcepts body and tacking it down with CA and Goop.
Like this only bigger:
Zerodefect is offline
Old 06-08-2010 | 03:15 PM
  #4363
havatitan's Avatar
Dude, you gotta post a vid of that running around the track.
havatitan is offline
Old 06-08-2010 | 05:24 PM
  #4364
ThunderbirdJunkie is cheap, so he didn't spring extra for shipping, but his new junk should be here tomorrow.
Because of his run-in (runout? Geddit?) with the Jconcepts wheels, he figures he'd be similarly unhappy with the JC tires. If the beadlocks won't mount up to the AKA tires he has now, he'll probably just glue the AKAs to the stock SC10 wheels he's got and hang on to the beadlocks.
Just curious.
You know you want to. Give in. Just do it.
http://www.amainhobbies.com/product_...Subaru-Impreza
Old 06-08-2010 | 08:35 PM
  #4365
bjholz's Avatar
My local course is getting a SC indoor track. I have a Novak GTB with 10.5, a Futaba s9551 servo and spektrum reciever. After I pick up a SC10, am I good to go? Is that servo torquey enough? How do the GTB's run in these cars?
bjholz is offline
