SC10 Thread
Old 10-09-2009 | 10:30 AM
  #2851
balistic's Avatar
Originally Posted by Pimpin
i would love for you to drive mine and see what you think. Then i can help you adjust yours to your driving.
cuz lets face it....not every setup works for every driver.
when do you go to hot rod?
Tuesday the 20th will be my next time out, unless dirt bike plans fall through on the 17th.
I have the purple and orange trucks.
balistic is offline
Old 10-09-2009 | 10:50 AM
  #2852
balistic's Avatar
Originally Posted by xraysteve
is anyone using the rpm gt2 rear arms. I got a set but it looks like you have to put the left arm on the right and the right side on the left. So the shocks fit or am I just crazy.
I used the AE parts and cut the shock mounts off and drilled a hole in the arm to mount the shock. you could do the same with RPM arms.
balistic is offline
Old 10-09-2009 | 11:21 AM
  #2853
Ok I think that's a Tuesday. We usually moto at milestone mx on those nights but I'll try to make it out.
I have the all white truck with black factory motorsports stickers.
Pimpin is offline
Old 10-09-2009 | 11:24 AM
  #2854
z50king's Avatar
I got bowties!!
z50king is offline
Old 10-09-2009 | 03:38 PM
  #2855
rcman1993's Avatar
Originally Posted by tom_chang79
It's all in the tires. No amount of suspension compensation can compensate treads... Also, can't expect these things to handle like a T4. It's based off a T4, but the CORR style tires are drastically different...
Speaking of tires (and wheels):
How are the Proline Split-Six? Was thinking about getting a pre-mounted Proline Split-Six Bowtie for my SC10. Is the part of the rim where it mates with the axles for the rear rims beefy (meaning, the drive pins will not tear it up like the original SC10 rear rims)?
Anyone have a pic of the INSIDE of the rear rims of the Split Six? All I can find are the outside pics...
traction is traction, they just grip better on the sc.
rcman1993 is offline
Old 10-09-2009 | 06:28 PM
  #2856
xraysteve's Avatar
What do you do to change rear toe and what do you run. I was thinking like 3degree toe in. What is the stock setting. Where could I find set up sheets.
xraysteve is offline
Old 10-09-2009 | 06:30 PM
  #2857
rcman1993's Avatar
stock should be 0 to .5
Old 10-09-2009 | 07:21 PM
  #2858
whipnet's Avatar
I picked up one of those STRC battery straps and gained some weight lost to using lipo. Great solid piece.
STRC Battery Strap for SC10 #9814s <-- See info here
whipnet is offline
Old 10-09-2009 | 10:00 PM
  #2859
Fabulous's Avatar
This is what I am running in my T4. Just ordered another 'steel' one for the SC10. Adds 1 degree toe in and has 1 degree anti squat built in. The steel one adds more weight to tghe rear also.
http://www.rctech.net/forum/r-c-item...ok-inside.html
Fabulous is offline
Old 10-10-2009 | 01:41 AM
  #2860
trdsupra88's Avatar
Sc10 is 3* stock rear toe...
trdsupra88 is offline
Old 10-10-2009 | 04:24 AM
  #2861
tom_chang79's Avatar
I have a question. What size bearings do you need to replace those bushing used in the steering cranks? I'd like to replace those copper bushings with some good bearings to prevent the buildup of slop that will eventually happen from wear...
Anyone?
tom_chang79 is offline
Old 10-10-2009 | 06:21 AM
  #2862
Anyone?
1/8" x 1/4"
Pimpin is offline
Old 10-10-2009 | 06:25 AM
  #2863
speeddaddy's Avatar
Anyone?
You can get them at ( WWW.AVIDRC.COM) They are1/8x1/4 Metal.( Part # R144ZZ). All there bearing are only 1 dollar each, best price any where. I've been buying from them for a long time. Guys I race with told me about this place
speeddaddy is offline
Old 10-10-2009 | 10:26 AM
  #2864
xraysteve's Avatar
Avid is a great deal. I am still putting my kit together and no the RPM gt2 rear arms don't fit and the front RPM gt2 arm work but you have to buy smaller hinge pinns. And if you are almost done building and you get to the shock build step make sure you leave like a hour extra for just trying to get the shock caps to thread on straight.
Old 10-10-2009 | 12:09 PM
  #2865
balistic's Avatar
where are you getting that number from?
balistic is offline
