SC10 Thread
Old 11-18-2010 | 03:49 PM
  #5101
offtraxx's Avatar
Originally Posted by C_Money
Also on carpet sometimes I have the hardest time steering, it just pushes.. Would gluing the servo saver be the fix? I have tried about everything else.
try moving the batt all the way foward, lighter oil in the diff (loosen ball diff), add weight to the nose, and clean or traction compound the front tires. or try the black ae servo spring. it's a little stiffer than the stock one. if none of this helps, then glue
offtraxx is offline
Old 11-18-2010 | 04:39 PM
  #5102
WillD's Avatar
Just installed the FT titanium front axles after I stripped the threading a little on the stock axles. What a neat little upgrade, instead of holding the wheel on with a locknut, all you do is screw in a button head screw that goes straight into the axle. Plus it's titanium, so you save some weight too
WillD is offline
Old 11-18-2010 | 04:47 PM
  #5103
ShortCourseOnly's Avatar
Make sure you lock-tite the screws. I had them loosen up during a race until the screw fell out.
ShortCourseOnly is offline
Old 11-18-2010 | 04:49 PM
  #5104
If you can't get the steering you want with these changes then you can stiffen the rear suspension and soften the front so that weight transfer can help front traction. The rear sway bar may help too.
Old 11-18-2010 | 04:52 PM
  #5105
WillD's Avatar
Already done
WillD is offline
Old 11-18-2010 | 05:14 PM
  #5106
Did all this.. I am just gonna crank the nut way down first before I glue.. It turns way better than it did just everynow and then it wont
C_Money is offline
Old 11-19-2010 | 02:05 AM
  #5107
mjk1210's Avatar
Well, yeah. Nobody said it, but tighten the servo saver all the way down FIRST. It should be way better after you do that.
why didn't I think of that?
NEVER ASSUME guys. right?
mjk1210 is offline
Old 11-20-2010 | 10:10 PM
  #5108
mini696's Avatar
What brand servos does the stock steering arm fit. ie. is it a Futaba/JR style?
mini696 is offline
Old 11-20-2010 | 10:17 PM
  #5109
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
It should come with servo horns to fit all servos
T-BirdJunkie is offline
Old 11-20-2010 | 10:28 PM
  #5110
mini696's Avatar
I'll check my kit, but I believe I only got the one. It was an RTR.
mini696 is offline
Old 11-20-2010 | 11:30 PM
  #5111
Wet day at the track
And a shot to show the snazzy transponder mount. No shoe goo here, folks! All screwed in from the TOP of the chassis
Old 11-21-2010 | 04:39 PM
  #5112
I like the transponder number on the body. lol
Krio is offline
Old 11-21-2010 | 08:06 PM
  #5113
ThunderbirdJunkie spares no expense on his custom, hand-drawn numbers
Old 11-21-2010 | 08:36 PM
  #5114
racer1812's Avatar
Super Moderator
I don't care who you are, that's funny
racer1812 is offline
Old 11-21-2010 | 08:56 PM
  #5115
WillD's Avatar
T-Bird, you need your own thread in the Paint section. Gotta show those pros how to really lay down some paint
WillD is offline
