Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 06-02-2010 | 01:56 PM
  #3241
houston's Avatar
Tech Prophet
Originally Posted by jonw
Monty
Check in the mail priority sent yesterday.
Jon
sounds good jon
send me an email with exactly everything we are doin for ya
houston is offline
Old 06-02-2010 | 02:30 PM
  #3242
jonw's Avatar
Originally Posted by houston
sounds good jon
No problem, look for it this evening.
jonw is offline
Old 06-02-2010 | 03:04 PM
  #3243
TommyBlazin's Avatar
houston, are you tuning the new 4-c team motors? or are they just leave em be?
TommyBlazin is offline
Old 06-02-2010 | 03:37 PM
  #3244
houston's Avatar
Tech Prophet
i still do all my stuff to them if people want it done , filled crank for truggy
houston is offline
Old 06-02-2010 | 06:18 PM
  #3245
so its doubly tuned?lol...do ur mods grant more runtime? smoother power delievery? etc...hold tunes better or a lil more skiddish as its a mod? thanx...pm you btw
Old 06-02-2010 | 06:41 PM
  #3246
jonw's Avatar
Monty
Check your phone for a text.
Jon
jonw is offline
Old 06-02-2010 | 08:50 PM
  #3247
houston's Avatar
Tech Prophet
Monty
Jon
i got it mr.
houston is offline
Old 06-02-2010 | 08:53 PM
  #3248
houston's Avatar
Tech Prophet
it says in your sig that AB (adam blevins) does your offroad engines
the tuning that i do accentuates the whole engine , i have not noticed any ill effects on tuning , low end or longevity and have had many happy customers , many are repeat , i guess i must be doing something right
houston is offline
Old 06-02-2010 | 10:11 PM
  #3249
CKmaxx's Avatar
The tuned FMS I received from Monty is the best running engine I've ever had and I've had many. It would probably run the same bone stock because it's a Novarossi but Monty's tune definitely didn't make it unreliable.
CKmaxx is offline
Old 06-03-2010 | 01:13 AM
  #3250
Lonestar's Avatar
Hi Monty, I'd love to hear from you about my previous Q on which inserts fit the NR carb as the NR 6.0mm is out of stock in most places that ship overseas... Do the GRP ones fit? Reedy ones? Any idea? Thanks
I also got my hands on a N21BF (great little mill, was on sale at my LHS, couldn't resist as I had run one previously in an endurance race at it was really really perfect for my driving skills, not to mention runtime and clutch/tyre wear)... and I don't run turbo plugs on my +4, so basically I have a spare turbo insert... Any advantage in installing on my N21 as I have a crapload of Odo 97T in stock?
Thanks for the help Paul
Lonestar is offline
Old 06-03-2010 | 02:26 AM
  #3251
Lille-bror's Avatar
Hi.
The Scandinavian Novarossi distributor (northtq.com) has 2! of those 6 mm inserts in stock. I'm going to buy 1 of them, and can buy and send the last to you.
Lille-bror is offline
Old 06-03-2010 | 09:47 AM
  #3252
Rick57's Avatar
Hi Monty,
I do not know if you remember me. Rick from Roswell, Ga. I bought a Plus 21-4C and a 9901SS pipe/41021 header set from you several months ago. I have finally gotten it broken in and working on a "race tune". I have tuning question. The bottom seems to lack snap and the top seems to fade to soon. That pipe set should give me solid bottom performance? It appears to be rich. When I lean the HSN the temps jump and the performance drops. Can you give me base line needle settings for a "race tune"? Currently I am running the HSN at 3.50 from flush and the LSN 5.25 from flush. I am thinking the LSN is too rich. What is a good temp for the 21-4C. I also notice the the tip of the LSN appears to be bent ever so slightly. Will that have a big effect performance? I am aware that when adjusting the LSN the slide needs to be completely open or it will damage the needle. Thanks again for you help!
Rick57 is offline
Old 06-03-2010 | 07:10 PM
  #3253
houston's Avatar
Tech Prophet
Originally Posted by Rick57
Hi Monty,
4.25 on low and around 3.5 on high , your carb balnce is way off . try a 6mm restrictor in buggy
yes i remember you , rick french , g&w associates?
houston is offline
Old 06-03-2010 | 08:21 PM
  #3254
I have a fms and +4 that are just now breaking in. What shims should I be running with Byrons 30%? What do you think about the Pro Driver fuel with 9% oil? I have been running the race gen2 so far but one of the local hobby shops only stocks the pro driver.
Thanks,
Rick
Tricky is offline
Old 06-03-2010 | 08:26 PM
  #3255
houston's Avatar
Tech Prophet
Thanks,
Rick
they are pre shimmed for 30% , 30/9 pro driver is excellent fuel
houston is offline
