Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 05-10-2010 | 06:54 PM
  #3091
houston's Avatar
Originally Posted by jonw
Monty
Good talking to you today. Thanks for the help.
Jon
Cade says "What's Up?"
good to talk to ya too Bro !!
tell Cade i said " Yo Yo Yo wussup lil buddy!!! "
houston is offline
Old 05-10-2010 | 07:16 PM
  #3092
Suspended
ok....got a nova .21bf modded by jim hottinger, need a rod for it. is there any other rod that will work or do i need a nova .21bf specific rod? i know they are only 34.00 new but was just wondering, found others that say will fit any .18 to .21 for 20.00, any help would be great, thanks, mike
inferno13 is offline
Old 05-10-2010 | 07:36 PM
  #3093
tkge's Avatar
Default N21R needle settings
Can anyone tell me what factory settings are for the N21R, what they should be for break in and what is a good tune setting?
Thanks!
Tim
tkge is offline
Old 05-10-2010 | 07:54 PM
  #3094
houston's Avatar
if its an n21bf limited or n21r limited you can use the R7 (07009) rod , if it is the older n21b 2001 you will need 07030 . 99% sure on the old rod fitment and part#
r7 rod is 50$
houston is offline
Old 05-10-2010 | 07:57 PM
  #3095
houston's Avatar
Thanks!
Tim
factory on the n21r carb is 5 turns out on low speed ( pull slide barrel out , run screw in until it just stops , then backout to desired setting ) , high speed needle 4.25 turns out , idle 1.25 out from just closed .
race settings are usually around 3.75 turns on low speed , 3.5 turns out on high speed , 1turn out from just closed on idle screw .
any Q's just let me know
houston is offline
Old 05-10-2010 | 08:12 PM
  #3096
Cory Kerber's Avatar
Monty mine is 3 out on the lsn, and 1.5 out on the idle. Hopefully that's not too lean.
Cory Kerber is offline
Old 05-10-2010 | 08:26 PM
  #3097
tkge's Avatar
Thanks!!!
Tim
tkge is offline
Old 05-10-2010 | 09:28 PM
  #3098
houston's Avatar
Those settings are very good starting points for any pipe combination , low end based pipes are usually a little rich onthe low compared to the high speed pipes
houston is offline
Old 05-11-2010 | 06:08 PM
  #3099
houston's Avatar
Plus 4 team's and p5xlt's available as well as competition heat heaters , 2084ss pipes and 9901ss pipes , get em while you can
houston is offline
Old 05-12-2010 | 08:49 AM
  #3100
tarpon140's Avatar
Monty, how does the 2084 pipe do on the FMS? Compared to the 9901?
tarpon140 is offline
Old 05-12-2010 | 09:02 AM
  #3101
hambone's Avatar
Well i'm not Monty and i haven't tried the 2084 yet, but i can tell you for a fact that probably any pipe is better on the fms than the 9901. Did alot of pipe testing on my fms and the 9901 was the only pipe that fell into the "it sucks" league.
hambone is offline
Old 05-12-2010 | 09:04 AM
  #3102
houston's Avatar
Agreed Rob
9853ss and 2084ss w/41021 header are both awesome pipes for the fms , heads and tails better than the 9901ss
houston is offline
Old 05-12-2010 | 09:10 AM
  #3103
tarpon140's Avatar
Agreed Rob
And the 41021 is the same as the 41029 other than tighter turn for Mugen, right?
Old 05-12-2010 | 09:18 AM
  #3104
tarpon140's Avatar
Short header, right?
Old 05-12-2010 | 09:39 AM
  #3105
hambone's Avatar
The 41021 is called a short curved header but it is actually .200" longer than the 41005 "[" shaped manifold that is referred to as a medium length, go figure. Those 2 work well, but the 41001 didn't, it's .100" shorter than the 41005, same shape.
hambone is offline
