Serpent 710
#3961
Wouldnt the using softer tires mask any setup problems you may have?
Sure, you may see the conning of the tires quicker, but thats not a real good indication of what the suspension/chassis etc is realy doing.with the corect tires on it.
#3965
Originally posted by S710_Nut
The only thing i do not like about this car so far is the e clip on the 2 speed. the cut in the shaft seems to be too narrow or the clip is not big enough
#3966
SN
SN
#3967
the rear springs require more preload for ride ht because they have more leverage on them from the suspension arm, has to do with the shock being mounted on the arm instead of on the upright, same deal with the lsa conversion, this is also why large numbers of you have gone to the red rear springs to help loosen the rear of your cars.. make it feel like the old car.
#3968
Originally posted by InitialD
Are you checking the tweak with the rear sway bars on or off? Perhaps you need to check if the rear sway bar by itself can move freely without binding...
I try to explain better; my question is : When I lift the rear, is it ok if the rear springs become ‘uncompressed’ before the wheels lift the surface? Seems that the preload is not enough to ‘push’ the suspension arms down until the stop (done by the downstop grub screw, I mean).
TNX
#3974
Originally posted by GoldFinger
Down here, country with thousands island and problem either.
Sorry if im being so but i dont like that character either and I like the fact that he is faster than you..
#3975
the spring should be plenty long to push down, very very odd, with my spring couplers at the yop of the threads it pushes my arm to the grub screw,?? not sure.. can you posta pic?
