Go-Tech Engines Thread
#7681
Yeh I'm with mark..Visited the real world recently and it ate my 7 port..So back here in fantasy land consider my MG66 ordered..I guess the payment will have to come from the real world but you can't have everything ..right..well maybe not but I'm sure as hell gonna try..As my next race isn't till 3rd september I have all summer to run it in and play around with the buggy settings..might even get my trigger finger to bend by then...
HA! finger pic added..get a load of that!
You don't do things by half do ya bro - nasty job on the finger, but at least it's still all there. Seen a lot worse in my line of work, but it still got me wincing at the thought
Hope it heals real quick for you so you can be gunning that 66 in a little while from now
#7683
The lesson is don't put your figgin hand in the baling machine..
#7689
#7690
Mark does some crank work as well for the full stage 5 but that will cost you 125 bucks for the p/r/s as well as 120 bucks for the work so 245 total...I asked him what the stage 5 p/r/s would cost and he said 179 bucks plus postage..My crank pin is knackered..worn to a taper cause the crank was spinning at an angle as the bearing pushed out the bottom of the crankcase..I bet the new rod and pin I just fitted are ruined as well..certainly won't risk using them in anything else..so I am left with the MM5 p/r/s which I had ready in case I needed a replacement for my 7 port which was my main race motor..I should imagine the reworked sleeve will be fine with a standard crank..ask Mark to be sure..or you could always get him to just rework a crank..I don't know if crank pins can be repaired/replaced but I'm happy to include the crank at no extra cost if it can be fixed..
#7691
Well I got to around tank 10 with my Powerhouse mods 3 port race and its really running well. It has awesome throttle response and power output is increasing on each tank. Before todays 3 tanks I had the break in shim in I took it out for today. This mill is gonna be awesome. My PTM 5 port will be put up for just in case or if I ever go back to truggy.
#7692
lol well today our "alternate realities" will collide again..... i'll drop the 5 port off at the Massive Mods "day spa" for its annual therapy session.....
im pretty happy with 12 months racing and approx 40 litres through it!
it was absolutely flying on Sunday and i think Flanno was almost going to have to excuse himself for a bit of "quiet time" at one point after he drove it
Mike
Mike
#7693
Mike
Mike
Yep, a Stage 5 5 Port will do that to you if your not used to it
#7694
Cheers MM
#7695
I ran my 7 port for the first time on Monday. I'm running an OS carb and had some issues at first but got it started up and running decently. Top end still needed tuning but that's not what I stopped running.
One of the MIDDLE fins on the cooling head BROKE and was just laying on the one under it! How does this even happen? I didn't have any major spills and the wing and body protect the head so I'm still not sure how this even happened? Maybe the previous owner had a spill and didn't know?
Anyone got a 7 port head they don't want? I just need the head, not the button.
2Likes
