Like Tree2Likes
Go-Tech Engines Thread
Old 07-07-2009 | 01:31 AM
  #7681
grizz1's Avatar
Originally Posted by Gizmatron
Yeh I'm with mark..Visited the real world recently and it ate my 7 port..So back here in fantasy land consider my MG66 ordered..I guess the payment will have to come from the real world but you can't have everything ..right..well maybe not but I'm sure as hell gonna try..As my next race isn't till 3rd september I have all summer to run it in and play around with the buggy settings..might even get my trigger finger to bend by then...
HA! finger pic added..get a load of that!
He he - yeah, I hear ya Giz. The nitro fantasy world kicks the real worlds butt
You don't do things by half do ya bro - nasty job on the finger, but at least it's still all there. Seen a lot worse in my line of work, but it still got me wincing at the thought Hope it heals real quick for you so you can be gunning that 66 in a little while from now
grizz1 is offline
Old 07-07-2009 | 02:02 AM
  #7682
JPierson's Avatar
Exclamation
OUCH!!! Hope it heals fast for ya!! Dont know how your
Driving with it like that?
JPierson is offline
Old 07-07-2009 | 02:30 AM
  #7683
Gizmatron's Avatar
Very Carefully is the word for the month..hehe..trouble is when you're driving and not concentrating on the finger it tends to try and bend at the same time as the second finger I'm using on the throttle..OUCH!.My futaba 3pks is a heavy handset as well and it's not easy to hold firm with only 2 little fingers holding the grip..Supposed to have the stitches out tomorrow but the nurse says not likely the way it's healing..I'm betting several weeks before it's healed and then I bet I lose some flexibility in it due to the scar tissue just on the inside of the joint..
The lesson is don't put your figgin hand in the baling machine..
Gizmatron is offline
Old 07-07-2009 | 03:08 AM
  #7684
Gizmatron's Avatar
OK time for you all to go green...MG66 order is in...
Old 07-07-2009 | 03:30 AM
  #7685
grizz1's Avatar
grizz1 is offline
Old 07-07-2009 | 04:41 AM
  #7686
Gizmatron's Avatar
Any takers for the MM5 p/r/s set....$120 US inc free shipping!
Old 07-07-2009 | 07:59 AM
  #7687
bigmatt's Avatar
is this the basic set? stock?
bigmatt is offline
Old 07-07-2009 | 08:47 AM
  #7688
Gizmatron's Avatar
this is a complete p/r/s set brand new with a MM stage 5 job done on the sleeve..worth around $150 US plus postage..
Old 07-07-2009 | 10:40 AM
  #7689
bigmatt's Avatar
what about the crank?On the web site it shows they did some mods.
bigmatt is offline
Old 07-07-2009 | 11:00 AM
  #7690
Gizmatron's Avatar
Mark does some crank work as well for the full stage 5 but that will cost you 125 bucks for the p/r/s as well as 120 bucks for the work so 245 total...I asked him what the stage 5 p/r/s would cost and he said 179 bucks plus postage..My crank pin is knackered..worn to a taper cause the crank was spinning at an angle as the bearing pushed out the bottom of the crankcase..I bet the new rod and pin I just fitted are ruined as well..certainly won't risk using them in anything else..so I am left with the MM5 p/r/s which I had ready in case I needed a replacement for my 7 port which was my main race motor..I should imagine the reworked sleeve will be fine with a standard crank..ask Mark to be sure..or you could always get him to just rework a crank..I don't know if crank pins can be repaired/replaced but I'm happy to include the crank at no extra cost if it can be fixed..
Old 07-07-2009 | 02:46 PM
  #7691
Well I got to around tank 10 with my Powerhouse mods 3 port race and its really running well. It has awesome throttle response and power output is increasing on each tank. Before todays 3 tanks I had the break in shim in I took it out for today. This mill is gonna be awesome. My PTM 5 port will be put up for just in case or if I ever go back to truggy.
malik is offline
Old 07-07-2009 | 03:09 PM
  #7692
pantera nitro's Avatar
Originally Posted by MassiveMods
Real world ? whats that ?
lol well today our "alternate realities" will collide again..... i'll drop the 5 port off at the Massive Mods "day spa" for its annual therapy session.....
im pretty happy with 12 months racing and approx 40 litres through it!
it was absolutely flying on Sunday and i think Flanno was almost going to have to excuse himself for a bit of "quiet time" at one point after he drove it
Mike
pantera nitro is offline
Old 07-07-2009 | 03:58 PM
  #7693
grizz1's Avatar
Mike
Yep, a Stage 5 5 Port will do that to you if your not used to it
grizz1 is offline
Old 07-07-2009 | 09:19 PM
  #7694
MassiveMods's Avatar
Yes Gary that PRS Set will work with a standard crank .
Cheers MM
MassiveMods is offline
Old 07-08-2009 | 07:17 AM
  #7695
I ran my 7 port for the first time on Monday. I'm running an OS carb and had some issues at first but got it started up and running decently. Top end still needed tuning but that's not what I stopped running.
One of the MIDDLE fins on the cooling head BROKE and was just laying on the one under it! How does this even happen? I didn't have any major spills and the wing and body protect the head so I'm still not sure how this even happened? Maybe the previous owner had a spill and didn't know?
Anyone got a 7 port head they don't want? I just need the head, not the button.
gtxracer is offline
