Go-Tech Engines Thread
#7068
#7070
#7071
ok question got to go 5 port gen 5.5 1 has long lsn ( stays in at full open) the other i think has a short lsn ( comes all the way out at full open ) now the long lsn motor runs and tunes great no issues now the one with the short lsn is harder to tune it seems the pinch test is inconsistent can run 3 or 4 laps check it and its fine then after another 3 to 4 laps it is too lean the motor as a ton of power but the od thing is when it idles it is fine but if it flips over it flames almost sounds like it loads up and dies any ideas on what this could be thanks.
#7072
#7074
Done a couple of tanks with it in and it seems great. Not as hot as the P3, probably equivalent to a P4, which is fine.
#7077
#7079
im pretty sure that needle setting factory are flush thats what they were on my 3 port i have the instructions and they say 3.5 turns out from fully in top end and bottom end 1 turn in from flush hope that helps
#7080
thank , WES
Dallas Texas
no one here knows about the GOs but there learning LOL
2Likes
