Like Tree2Likes
Go-Tech Engines Thread
Old 06-03-2009 | 11:22 AM
  #7066
Get a DONUT racing head its $5 more but its cross drilles to be light and proven on GO's. It was made for the EBM5's but will fit them all. And look sick and are all CNC.
malik is offline
Old 06-03-2009 | 11:24 AM
  #7067
Get a Donut racing head.
malik is offline
Old 06-03-2009 | 06:20 PM
  #7068
chim13's Avatar
i would check out the head that Ed made for the go engines they are very very nice. www.ebmods.com
chim13 is offline
Old 06-03-2009 | 07:07 PM
  #7069
pl_unc86's Avatar
Anything wrong with running the ninja jx pipe with the c header on the 5 port turbo go tech?
pl_unc86 is offline
Old 06-03-2009 | 09:10 PM
  #7070
grizz1's Avatar
Nope. A mate of mine runs that exact same set up in his truggy, and it hauls butt big time
grizz1 is offline
Old 06-03-2009 | 09:54 PM
  #7071
ok question got to go 5 port gen 5.5 1 has long lsn ( stays in at full open) the other i think has a short lsn ( comes all the way out at full open ) now the long lsn motor runs and tunes great no issues now the one with the short lsn is harder to tune it seems the pinch test is inconsistent can run 3 or 4 laps check it and its fine then after another 3 to 4 laps it is too lean the motor as a ton of power but the od thing is when it idles it is fine but if it flips over it flames almost sounds like it loads up and dies any ideas on what this could be thanks.
teamreidy is offline
Old 06-03-2009 | 11:17 PM
  #7072
grizz1's Avatar
Your tank level will have dropped considerably after another 3 - 4 laps, so everything will be a little leaner I would expect. I would'nt think it would load up when it's upside down, as the fuel pick up would be uncovered. The length of the LSN shouldn't matter too much, as long as you have tuned each type of needle appropriately. Either motor should run the same. Have you got the fuel tubing routed differently ? Check your fuel system out thoroughly. Look for fuel tubing pin holes, needle O rings leaking, leaking fuel tank or faulty tank lid O ring or spring. Funny little changes in the way an engine runs like that are quite often not a tuning problem, but something outside the motor.
grizz1 is offline
Old 06-04-2009 | 12:51 AM
  #7073
triplesix's Avatar
Default GO Glow Plugs
Hey guys,
anyone out there who has already tested GO glow plugs?
I've been running OS P3s with great results so far...
Regards,
T
triplesix is offline
Old 06-04-2009 | 01:01 AM
  #7074
grizz1's Avatar
Originally Posted by triplesix
Hey guys,
Regards,
T
Running a T3 (Hot) in my 7 Port this Sunday, so will let you know.
Done a couple of tanks with it in and it seems great. Not as hot as the P3, probably equivalent to a P4, which is fine.
grizz1 is offline
Old 06-04-2009 | 01:06 AM
  #7075
I ran the new Go hot plug on the weekend and it worked perfectly, i normally run os p3 and didnt notice any difference, and the bonus is they are cheaper than os!
infernotb is offline
Old 06-04-2009 | 02:26 AM
  #7076
triplesix's Avatar
the german go importer, who races at the same locations like i do, gave me a T3 to try it, but i didn't put it in by now. i'll throw it in at the race next weekend.
thx guys!
Old 06-04-2009 | 02:59 AM
  #7077
grizz1's Avatar
Hi Tony, How are you finding the "Pure" fuel ?? Boys are looking forward to a big meeting this Sunday. The track is perfect, and it doesn't look like it is going to rain for a change. Yaaaay
grizz1 is offline
Old 06-04-2009 | 05:21 AM
  #7078
jeremy reed's Avatar
Default neddle settings
was wondering if anyone would be able to tell me the factory needle settings for the go 3 port standard engine?thanks,jeremy
jeremy reed is offline
Old 06-04-2009 | 07:30 AM
  #7079
mattwoodcraft's Avatar
im pretty sure that needle setting factory are flush thats what they were on my 3 port i have the instructions and they say 3.5 turns out from fully in top end and bottom end 1 turn in from flush hope that helps
mattwoodcraft is offline
Old 06-04-2009 | 07:39 AM
  #7080
Default help
im going to be grabing a mass mod GO is the 3port r pipe combo good or will i like the modded 3port r better and if so which pipe i currently use 053 on my 7 port but been have issue with that mill (crack case, now loose rod @ top bottom) it going to MM now and i am thinking aboubt the 3r we have a tight track indoor 110' straight sometime 150'
thank , WES
Dallas Texas
no one here knows about the GOs but there learning LOL
leapinglizard is offline
