Go-Tech Engines Thread
#2551
Hey Brian i ran my buggy today at out local track and it all went good. i was trying to keep it in the 220 range usually staid around there and near the end of the tank it went up to 250 to 270 so it should be fine. Also the low end was pretty good but i had no top end at all i was wondering what i should adjust.
#2552
If anyone has the old style LSN try it in the new carb
Jason, they havn't come in yet.
Garrett, richen the hsn, we are running almost flush on the HSN and a few full turns ion on the LSN, should get you in the ball park.
The 3 port sport sleeve will lose the metal pinch faster than the 5 and 7 ports, put a racfe tune on it and letter eat
#2553
Does anybody know where I can buy go tech engine parts - specifically the engine crank case for a .25R? Here's my story (do not read if faint of heart!):
Spent all day breaking in my new Go Tech .25R in my brand new 8ight-T. Was taking it really slow and following all the break-in rules as it was the first race engine that I've owned. Had the local track/LHS owner helping me. Was on the fifth tank and just starting to give short WOT bursts. Had a electrical issue (don't want to mention what it was as is embarrassing), can ran away at full speed, hit the underneath of a parked car at full speed and literally ripped the engine out of the truggy. The engine case fins are still firmly bolted to my engine mount and the engine case has huge holes were it was ripped out of the car. Never even got a single lap on the track. I was seriously in shock packing up my stuff at the track. Was seriously on the verge of sticking everything left on ebay and walking away from the hobby.
So if anyone knows where I can get an engine case I seriously would appreciate it. I will say that it was sounding so good before the brain fart on my end that I think I'm actually also gonna buy another one as well as fixing my first one.
#2554
#2555
hey guys i had seen somewhere in here that a few people had a problem with the lower oring tearing up on the gotechs....i had a similar problem ...when i initially checked the the carb it seemed like it rocked from side to side just a touch ....so thats what prompted me to remove the carb and check things out ...the oring was torn so i got new ones and replaced them on both of my go's 5 and 7 ports ....my problem is this ...on the 7 port the carb still rocks back and fourth just a touch ...it has been pressed down as far as it can go and tightened snug ....has any one had this issue ? or can put me on the post number where it was explained ...any and all help appreciated .....thanks brian
p.s. the 5 port seems good and snug
#2556
if your talking about the o ring that seals the carb and the engine i recommend sealing that part with rtv my carb didn't move but it still had a bad leak replace the oring when you can get one then seal the carb going into the engine
#2557
do the 3port sport suppose to lose some of the pinch during break in? I have 4 tanks on it and the compression do not feel as tight anymore. I can rolll it pretty easy with my hand, temp no higher than 207. My p7r has about 1/2 gallon it and it is super tight, temp on it is around 225 to 230. But still blow lots of smoke. should i send it back or what?
#2559
I have a turbo button head for it when should i install it? your commits please, thank you.
#2560
#2561
Go engines do not hold pinch nearly as long as Picco engines do...Picco uses a harder billet piston material which takes longer to wear into the sleeve...Go use a softer cast piston that wears in much faster then the Picco will....... so everything your noticing is perfectly normal..
#2562
#2563
I have never run a Go 3 port, so I am not sure if adding a turbo button will increase top end... I usually find turbo plugs give a motor crisper throttle response and a more consistent idle as well as longer lifesapn..the motors seem to feel stronger possibly because the throttle response is crisper, but I am unsure if you would see much HP or RPM gain on a dyno...... myself I definitely prefer turbo motors to standard motors and I feel they are well worth the extra cost
#2564
hey all im setting up an 8t and was curious to know which go-tech engine I should run? My last .28 was in my opinion a little to much. And Im not sure about there .25 could anyone in here help me select the correct model.Id sure appreciatte it. Thanks,Lee
2Likes
