Like Tree2Likes
Go-Tech Engines Thread
Old 04-20-2008 | 06:34 PM
  #2401
zJatoRad's Avatar
Hey guys, I have about 2 gallons through my .21 5 Port Turbo and I can't get more than 6 mins out of a tank, temps are at 250 and don't want to lean it more, are the restrictors the only thing I can do to increase the run time?
clebo3, I've had my .21 5 Port Turbo run at 300 once or twice and that sucker is still tight, I mean, I can turn the flywheel but it's very hard, I think you should be okay.
zJatoRad is offline
Old 04-20-2008 | 06:35 PM
  #2402
maycam10's Avatar
no its 125 i just added to my cart and it said 125
maycam10 is offline
Old 04-20-2008 | 06:39 PM
  #2403
Furadi's Avatar
It just went up There getting smart and realizing that Go's are under priced, especially the 3 sport.
Furadi is offline
Old 04-20-2008 | 06:42 PM
  #2404
Brandon Melton's Avatar
Wow, what pipe are you running? A friend of mine pitted at 10 mins this weekend to make it on two stops in a 30 min main, he almost always gets 11 mins. Temps at the end of the run was 235.
Brandon Melton is offline
Old 04-20-2008 | 06:46 PM
  #2405
maycam10's Avatar
ya i know. well thats sucks
maycam10 is offline
Old 04-20-2008 | 06:53 PM
  #2406
Furadi's Avatar
Only went up 10 bucks
Furadi is offline
Old 04-20-2008 | 07:02 PM
  #2407
rawdawgga's Avatar
Default 3 poet race
where can i find the 3 port race, & how much?
rawdawgga is offline
Old 04-20-2008 | 07:21 PM
  #2408
zJatoRad's Avatar
I'm running JP-4.
zJatoRad is offline
Old 04-20-2008 | 07:35 PM
  #2409
skeller's Avatar
I can get 8 1/2 min on my 5p turbo pretty regularly with the 086 pipe with temps around 240-250.
skeller is offline
Old 04-20-2008 | 07:59 PM
  #2410
Mr-s413bt's Avatar
Hey Guys.
Yeah i have a slight issue with run time... i get 7:55 - 8:05 with my 5pt running a GO2045...
Yet i easily get 9+ with my V-spec and the same pipe...
Mr-s413bt is offline
Old 04-20-2008 | 09:53 PM
  #2411
22Racer's Avatar
I sent you an e-mail Derricklong, We've been out of town all weekend racing in round 1 of the Minnesota Nitro series.
Go's are really catching on here! In expert buggy a pair of 7 ports placed 2nd and 5th. All of them ran awesome all weeekend.
In truggy my son who just joined Team Kyosho got second with a Govarossi! (I put a modded Go crank and rod in a Novarossi P5X, ran awesome!)
Rex
22Racer is offline
Old 04-20-2008 | 10:26 PM
  #2412
zJatoRad's Avatar
do you guys think it's the pipe (JP4)?, I also have a JP3 and a Hyper 2059 pipes, I'll give the 2059 a try and see what happens.
zJatoRad is offline
Old 04-21-2008 | 05:27 AM
  #2413
Very well could be, I went from a JP-4 to a 2050 (borrowed from TKO's Peter Martin) on my V-spec, and holy cow what a difference, it gained an extra minute and also ran with alot more snap and top end. So far I am not impressed with the JP-4. I am really dissapointed in knowing that I may be looking at $125 for a pipe, but I couldn't believe the difference it made.
Chris went to a 2060 on his 5 port from the 086 and it woke it up as well, but his mileage was about the same.
Old 04-21-2008 | 05:49 AM
  #2414
vti-chris's Avatar
Mileage depends mostly on "finger" and track layout.
Then comes engine, exhaust, plug,...
vti-chris is offline
Old 04-21-2008 | 11:06 AM
  #2415
zJatoRad's Avatar
well our track has a long straightaway but after that it's all technical and a lot of torque is required because there are a lot of jumps after corners but still, other engines are getting better fuel mileage.
I'll give the 2059 pipe a try this weekend and post the results.
zJatoRad is offline
