Go-Tech Engines Thread
#4051
Nice hint to MM mate. He might take pity on us
Yes, Paul was saying his 3 R was breathed on by Cliff our rocket fuel mixer (very talented engineer by all accounts) - sure made a difference. Paul said it was the smoothest off-road motor he has owned. It still had some metal pinch left on Sunday (only got leaned out a little for the A Final) and was keeping up with pretty much everything out there down the straight, but was very easy to drive through the tight stuff.
Good old Kiwi ingenuity strikes again.
How are you finding the new fuel ? Seems to be the way to go I think.
My 7 port is rocking. Just put a new rod in today as recommended, now that the initial metal pinch has pretty much gone (around 1.5 gal). The old one was in good shape when it came out, but better safe than sorry
Wanted to do it before the WRC so I can fang it real good
Possibly looking at a modded motor for the coming summer months. All depends on how nice the tax man is to me
#4052
Yep the new fuel is the biz,
the engines run a lot cooler, better run time, definate improvement in power, easier to tune and a more consistant Idle.
It's hard to believe that my 7port is nearly 2 years old and still goin strong, but I guess if you look after it properly it'll look after you
Adrian
Adrian
#4053
Okaaay - looks like the clear stuff is the way to go for sure. Will use the last of my 25/10 up and make the change.
Yep, you've had a good run out of that 7 port for sure. What you say is quite right though. If you treat things well they will last, plus fiddling around maintaining your motors and cars is half the fun. Is for me anyway
#4054
Is there anyway to contact racefactor besides the email listed on the site. I was in contact with them a few weeks ago and they were going to send me a new carb for my 5 port but nada has come in the mail and I am not able to send emails to them think something on their end. I went ahead and bought a new ninja cuz I needed a motor to race but still would like to use 5 port as backup.
#4055
Rex
#4056
I bought it from Brian on this site cant remember his exact screenname. Dana had said She just needed my address and she would ship it out. I told her I could send back the old one with proof of purchase but she said I did not need to. Not really a big deal its only been not even two weeks since I talked to her. Ill wait a few more then try again. I just dont know if its a email problem on my side or theirs.
#4057
Just like to get some opinions from 7 Port owners on the Dynamite 053 vs the Go 0801 pipe.
I changed from the 053 to the 0801 a month or so ago but it's been so wet here that I have only had one chance to race it properly since then. The 0801 is very nice on the 7 port, but I am going to change back to the 053 for a direct comparison. From memory the 053 performed a little smoother right through the range, but may have lacked the punch of the 0801. Any comments or recommendations from lucky 7 port owners out there would be appreciated
#4058
Between Os and Novarossi thats more than half the motors out there. Rb is also the same.
As far as updating the carb, if 500 people have Go's on this board and only 3 have had trouble I wouldn't think there is really a problem to fix. I've had Novarossi carbs do this before and 1/2 of Os carbs the insulator stays in the motor.
Rex
Rex
Cheers MM
#4059
http://go-engine.com/products.htm
the P series engines run standard plugs and the PT series engines run turbo plugs
hope this helps to clear up some of the confusion
Adrian
#4061
I have a GO 21 7 port and a GO 28. Both the stock cranks from the factory look like they were widdled with inferior hand tools. The ebay guys cranks are smooth as glass. If your a dealer it might be worth while to find out the whole story.
#4062
This guy claims to sell the modded crank which he also sells seperately.
the cranks shown on the EBay site are the new revised Gen 5 cranks they are the standard crank that now come with GO engines so if you have the Gen 5 series engine they should also look like that
#4063
I'm having a problem with my Go 7 port not wanting to thottle down... At first I thought it was a lean lsn so I retuned it.
Well, it seems no matter what I do I can't get rid of it. I'm running a Vspec carb if that helps anyone.
What besides a lean condition could cause this?
2Likes
