Go-Tech Engines Thread
#4036
I have a 21 3 port R that has around 3 gallons on it, the motor has been broken in the way Go-Tech recomended. My question to you guys is this....
Can I rebuild this engine with a 5 port sleeve and con rod or does it have to remain a 3 port? I was hoping to get more life out of it but that's nitro racing.
By the way, the 3 port had a ton of power.
) anyway does anyone know if the 5 port piston sleeve rod will work in the 3-port block?
#4039
Brian do you have any info about this new "PT" serie that Go is releasing:
http://www.buggy-sport.info/blank.ph...ontentid=10483
#4040
http://cgi.ebay.com/GO-21-7-2p-Turbo...742.m153.l1262
Mybe the PT version is like mugenb46, the PT might mean Pro Tuned or factory modified.
I just posted the link to show the mill. I would still rather buy a Go Tech engine from one of the reputable dealers here on RC Tech forum
#4042
As far as updating the carb, if 500 people have Go's on this board and only 3 have had trouble I wouldn't think there is really a problem to fix. I've had Novarossi carbs do this before and 1/2 of Os carbs the insulator stays in the motor.
Rex
#4043
Between Os and Novarossi thats more than half the motors out there. Rb is also the same.
Rex
Rex
#4044
It seems that some parts of the world are just a little bit slower at getting them or they wanted to sell off their older stock before importing the gen 5 engines
Adrian
#4045
There is a guy on ebay selling " Factory Modified" Go Tech engines.
the PT is the gen 5 engine , same thing .
Cheers !
#4046
Then switched to 802's when it dried out. Wicked tyres man !!!Paul ran his 3 Port and it went really well. Nice power band, he loved it.
Hey, that sounds like a certain Go retailer we know bro
No Gen 5's, no 0801 pipes - but I hear he is going to stock the new Rocket propellant you have been using
so that's something at least.CU at the WRC event. Should be awesome. GS and Go-Tech will have pretty good representation looking at the entries.
Later -
#4047
Hi Adrian, how's it going mate ? You missed a good days racing on Sunday. Track a little wet and puggy to start - VP Pro 804 Mini Pins worked a treat
Later -
Later -
sounds very much like it yeh, but things might change on that part thoughjust building my new ride and running in my gen5 5pt so I can't wait the WRC is going to kick a$$ and there are almost as many GO's as ninja's how bout that
I hear there was a bit of boxing action on sunday
#4048
Ah, yes - that was quite exciting in it's own right !!! Not content with one session, they ended up having 3 rounds in total - crazy. I know what should happen according to the club rules, so it will be interesting to see if both parties get the same punishment handed down.
I just paid my subs for this year last week too. Geez, if I had known they were going to carry on like that I wouldn't have bothered.
Anyway, back to the topic
Gen 5 - 5 Port ehh
Is it a MM modded version ? After having a drive of Pauls 3 Port the other day I am quite keen to try a MM modded Gen 5 - 3Port, but it will be interesting to see how yours goes in comparison. Mark at MM recommended a modded 5 Port for my buggy when I enquired a few weeks ago. So many choices
- it's great
#4049
Yeah, there's nothing modified about that, that is a 100% stock GO 7 port, this guy is basicly lieing on a national selling store, if it was properly modded all that heavy mass would be gone, and filled, the rod would be CNC cut for less weight, and the piston cut, along with improved case work, nothing modded on that Factory modded GO, this is what i have warned everyone about that finds these GO's on ebay for a great deal, you see FM and get sent a stock engine.
#4050
Gen 5 - 5 Port ehh
- it's great
Gen 5 - 5 Port ehh
- it's great
just a standard gen 5 and paul's 3port was modded by a kiwi and it looks like mines going there next as it's really improved on what is already a good engine.I would love to have a couple of Mark's (MM) engines (hint hint
)to run but they're just a little out of my buget unfortunately, but if I could afford it I'd have them tommorrow.
I'll probably save the 5port for the nats or the south islands and use my insane 7port in the buggy at the WRC meeting.
if you are interested in a MM engine talk to Paul as he can get them through Mark being the NZ distributor
Adrian
2Likes
