Like Tree2Likes
Go-Tech Engines Thread
Old 01-21-2008 | 10:12 AM
  #1351
free2day77's Avatar
IMO, the GO 2047, JP3, JP4 or even the Dynamite 007 is better than the 053... you need more bottom for a 7 port than the 053 will give
free2day77 is offline
Old 01-21-2008 | 10:26 AM
  #1352
I was at CRCRC this past weekend, and i started off running really well with the 7 port, awesome power. But by the third of fourth run, i could only get it to run for 2 minutes, kind of like low compression. at first, i thought we had missed the tune, but it kept happening. running super rich but turning 230. I thought the clutch went bad, so new springs and shoes. I ran again no better. I changed fuel tanks, lines, sealed the engine, and changed all the pipe gaskets and nothing. My last ditch effort i replaced the carb, and it was like a light switch other than not a good tune. I was happy with the engine speed wise, but dissapointed in the carb. the serial number was like 000000174. anything to worry about, or do i need to get a carb?
derricklong38 is offline
Old 01-21-2008 | 10:32 AM
  #1353
Rocket42's Avatar
Pressure test the carb you may find where it was leaking. it could have been a torn carb boot. or leaking at the seam. Let us know what you find.
I think the 053 is a good match for the 7port, it sounds to me like you would be able to get quite a bit more mileage out of the 053 with a little more work setting up the tune and clutch then the JP-3.
Rocket42 is offline
Old 01-21-2008 | 10:46 AM
  #1354
ok, that would be the best way to pressure test it?
  #1355
vr6's Avatar
vr6
for me i agree, the jp3 is a better choice 9mins on a jp3, about 8 mins(stretching it ) on the 053.
vr6 is offline
Old 01-21-2008 | 11:11 AM
  #1356
will g's Avatar
DOES THE JP3 WORK GOOD ON THE 5 PORT AS WELL
will g is offline
Old 01-21-2008 | 11:21 AM
  #1357
grizz1's Avatar
I initially ran a JP-3 on my 5 Port and it was "ok", nothing startling. I changed to an 086 Dynamite after reading the posts here and what a difference. I would recommend the 086 for the 5 Port in a buggy and also in a truggy for most tracks. If you run a really tight track with good grip then use the Dynamite 053 on the 5 Port (truggy only), it's a real stump puller combination. If the track surface goes away you might need to tame the clutch a little or go back to the 086.
I believe the 2047 is great on the 5 Port also, but value for money the Dynamite pipes are hard to beat
grizz1 is offline
Old 01-21-2008 | 12:46 PM
  #1358
Rocket42's Avatar
To pressure test the carb. remove the carb from the engine and clean it up, Get some fresh fuel tubing about 6" and a dish of water. Put the fuel line on the fuel nipple. Dunk the carb into the water with your index finger and thumb covering the openings, and blow into the fuel line. You should see your throttle body pushing out and if you see any airbubbles then you know you have a leak.
Rocket42 is offline
Old 01-21-2008 | 01:06 PM
  #1359
How well do you guys think the 3 port race engine will work in a truggy? Do you think it's probably a better choice to get the 5 port instead?
revo_race is offline
Old 01-21-2008 | 01:08 PM
  #1360
Jason Halvorson's Avatar
for truggy i would go with the 5port...truggies can use a little more bottom end...
Jason Halvorson is offline
Old 01-21-2008 | 01:13 PM
  #1361
will g's Avatar
I RAN A 3 PORT IN MY TRUGGY LAST WEEKEND AND IT RAN GREAT FOIR THAT TIGHT TRACK I WAS ON AND WAS A SPORT 3 PORT WITH TURBO BUTTON AND 5 PORT CARB . TOOK 7TH IN A MAIN NOT BAD FOR ME I WOULD RECOMEND A 5 PORT IN TRUGGY PLENTY OF POWER ALL OVER
will g is offline
Old 01-21-2008 | 01:15 PM
  #1362
Maximo's Avatar
Believe it or not but a carb can still pass this pressure test yet still have an air leak when installed on the motor.....It seems the metals in the carb can expand when it gets heat soaked and cause a air leak that will only appear when the carb is up to engine operating temps... The motor will tune and act perfectly for approximately 1 tank of fuel, after that a phantom airleak will apear as the metals in the crab get heat soaked.......
If in doupt seal the carb, testing for airleaks when the carb is cold will only tell part of the story....as the tolerances int he carb changes quite a bit as it gets up to operating temps....I have had several engines that were airtight when cold, but started leaking once they got hot... Always the same place, the seem between the metal end cap and the composite carb body
Maximo is offline
Old 01-21-2008 | 01:19 PM
  #1363
Rocket42's Avatar
+1 great info
Rocket42 is offline
Old 01-21-2008 | 01:34 PM
  #1364
i think thats where its coming from, but either my pit man sucks, or its leaking a pretty good amount of fuel.... th engine would be covreed by the end of a run... i really would like to figure it out, id hate to put this engine on the shelf as a dud
Old 01-21-2008 | 05:09 PM
  #1365
does anyone have a dino graph of the 5 or 7 port? my picco p7r evo is pissing me off that it wont stay running and i cant seem to find parts for it and if i could even afford them, so i have heard nothing but good things from go tech so might get one now that i need one. i run at realy small tracks and on a rare occasion a huge one.
rc10gt lover is offline
