Like Tree2Likes
Go-Tech Engines Thread
Old 01-18-2008 | 11:14 AM
  #1336
TripleX-JT's Avatar
Very Nice!!!
Josh Thompson
TripleX-JT is offline
Old 01-18-2008 | 03:10 PM
  #1337
MassiveMods's Avatar
Here are some more pics of the new R Spec , I almost had a woody when i first saw this engine ! The finishes and internals are world class !
Enjoy
Attached Thumbnails Go-Tech Engines Thread-img_1512.jpg   Go-Tech Engines Thread-img_1513.jpg   Go-Tech Engines Thread-img_1514.jpg   Go-Tech Engines Thread-img_1522.jpg   Go-Tech Engines Thread-img_1523.jpg
MassiveMods is offline
Old 01-18-2008 | 03:17 PM
  #1338
Jason Halvorson's Avatar
Enjoy
when i tore mine down i was blow away by the stock porting...this is one hot red head!!!
Jason Halvorson is offline
Old 01-18-2008 | 03:25 PM
  #1339
Ralph Walters's Avatar
Whats the crank look like?
Ralph Walters is offline
  #1340
  #1341
Old 01-18-2008 | 03:31 PM
  #1342
Vigilante212's Avatar
Looks sweet. I wouldnt order from that RC toro site anyway I try to stick with places I know
Vigilante212 is offline
Old 01-18-2008 | 04:17 PM
  #1343
thercshack.com is carrying the go tech motors for anyone .... they are here in Central IL. And alot of the guys that run there are using them.
I still have yet to even fire my .21 5 port
OWTKAST cpt is offline
Old 01-20-2008 | 12:21 PM
  #1344
guys just a reminder if your looking for a Go engine or a mod job talk to Brian at Pro Twister Mods...
Old 01-20-2008 | 01:24 PM
  #1345
will g's Avatar
got ? for everyone have a go 5port standard/turbo buttons i ran it this weekend to make sure good for next weekend and the head was leaking around where the button was what can i do to fix it or do i need to try something else- there are 2 shims in it now thnx will g
will g is offline
Old 01-20-2008 | 02:24 PM
  #1346
More pics of the internals and crank on my site
www.massivemods.com
Old 01-20-2008 | 04:51 PM
  #1347
Rocket42's Avatar
Will G, the shims may be bad, Or the engine got over tightened on one side, that can happen even if you tighten in a criss cross pattern but don't get all 4 bolts snug first. If youhave any bends in the shims replace them, if not try retightening the head.
Rocket42 is offline
Old 01-21-2008 | 08:14 AM
  #1348
vr6's Avatar
vr6
if you run an 053 pipe in the cold (like 10-20 degrees air temp) do you have to lean the motor out alot.
yesterday in joliet, il. track temps were like no more then 20 degrees. i didn't want to keep leaning my motor out alot. i was running a jp3 pipe before with awesome low end with great top end. temps for the motor were around 225 with very impressive power. as soon as i put the 053 pipe on, my high needed to be leaned out about 5 hours just to get anywhere near my motors sweet spot, but i still didn't like the power i was getting
decided to put the jp3 back on and loved driving with my go motor again
vr6 is offline
Old 01-21-2008 | 10:00 AM
  #1349
aznitronut's Avatar
Which engine are you using? 5 or 7 ? Which brand of 053 pipe?
aznitronut is offline
Old 01-21-2008 | 10:04 AM
  #1350
vr6's Avatar
vr6
7 turbo sportwerks 053
vr6 is offline
