Spektrum
#2416
Yeah, the M8 looked pretty straightforward. The M11 is an entirely different animal. Module plugs into the same place, but that was about it.
As far as plugs, another good place to check would be an auto parts store. A good one will have several sizes of plugs for firewalls, etc, to fill access holes and the like.
#2417
I have a question
I have a spektrum dx2.0 and want to get a spek micro RX
Will they work together? I know the micro is part of the pro series right?
The grey rx is just to big, and the little one would be awesome! Just dont know if they will work with the dx2.0, because its not pro series
And yes I read this page, but t doesnt answer my question, atleast I dont see it lol
#2420
ok well i got my standard DSM 3PK module the other day. And today i went out and bought 2 new micro spektrum rx's.
I go to bind them and for some reason it doesnt want to happen.
I plug the esc to the battery turn the esc on. RX flashes.
i turn on the 3PK and press the little button on the spektrum rx.
And still nothing
what am i doing wrong???
And still nothing
#2421
And still nothing
And still nothing
press and hold rx button.. wait for it to flash many times.
press and hold tx module button and turn on radio.
wait for the tx module light to flash many times and both rx and tx module light will be in a solid state.
hth
#2422
..I'm hearing the receiver for the new LOSI SLIDER that comes with the Spektrum radio will work in the regular Spektrum systems...
anyone here try them yet?
(They run about 1/2 the price of the normal spektrum receivers....)
#2423
And still nothing
And still nothing
#2424
It does work with the Spektrum modules, radios, and the DX3R. However I am not sure that the range is the same between the Losi and the Spektrum units. But if you buy a Slider have confidence in the fact that, if you want to use your own radio instead of the one it comes with, it will work.
#2426
#2427
#2428
I liked the one in my Slider so much, I bought one for my XXX-R Dirt Oval late model, and it works like a charm! The only thing I've noticed is that if I'm down at ground level (not up on the driver's stand), the range is a bit short ("fail safe" has kicked in twice in 4 weeks at about 120' or so -- not every time, just once in a while). However, once I'm up on the stand, it's flawless all night long. (190' indoor dirt oval)
#2429
hi,
so if I would to use my Futaba 3PK Spektrum module with the Losi DSM receiver, there will not be a problem right?
Sorry, if I asked a redundant question. I just would like to have a confirmation on that... it is much cheaper...
thanks for the great info!!
#2430
And still nothing
And still nothing
BTW, if your using the cap on the receiver, don't plug it in backwards. It will unbind the receiver.
