Spektrum
Old 09-10-2007 | 09:17 PM
  #2386
A Ilievski's Avatar
Will the Micro spektrum recievers work with the standard spektrum DSM 3PK modules?
A Ilievski is offline
Old 09-11-2007 | 06:55 AM
  #2387
RCGaryK's Avatar
Originally Posted by tw78911sc
Gary,
It is a DX2.0 with a SR3000. Thx Tom
OK, grabbed a DX2.0 and went thru the menus. Let's verify that you have your throws maxed out:
Press the Scroll Button 4-times until you get to the EPA screen
If it says TH on the screen, press the Channel button once to select the ST mode.
Turn the wheel to the right. This will allow you to adjust your throw to the right. When this is complete, turn the wheel to the left and adjust your throw to the left.
From here, Grip Button B will allow you to adjust your overall steering throw.
If this doesn't work, check to make sure your steering links aren't binding up, that your servo is working properly, and you may want to bind your receiver to a different transmitter to just double check if it is a radio issue.
RCGaryK is offline
Old 09-11-2007 | 06:56 AM
  #2388
RCGaryK's Avatar
Yup, the only thing you might notice is that combo will have a little more latency than if you used a Pro Series module with the Micro Receiver.
RCGaryK is offline
Old 09-11-2007 | 07:19 AM
  #2389
mac853's Avatar
Could somebody tell me, how long the minimum length which the wire of receiver antenna could be cut down to, please?
mac853 is offline
Old 09-16-2007 | 03:05 AM
  #2390
Yes i would also like to know this!
Jamie
jamie814340 is offline
Old 09-16-2007 | 04:12 AM
  #2391
haagar's Avatar
According to the DX3.0 manual the stock antenna is 8.5 inches and it can be cut down to 3.6 inches.
http://www.spektrumrc.com/ProdInfo/F...30ManualHR.pdf
It is on page 7.
haagar is offline
Old 09-18-2007 | 09:22 PM
  #2392
I have changed my 3pk to pro module & rx, but havnt same driving feeling compare with orginial hrs rx, the orginial one give more easy to drive than the pro module. Does anyone have same experience?
G2B Anthony is offline
Old 09-19-2007 | 09:53 AM
  #2393
mac853's Avatar
It is on page 7.
Thanks anyway
mac853 is offline
Old 09-20-2007 | 12:58 AM
  #2394
Born2Run's Avatar
A few months ago i bought a DX 3.0 for my electric cars.I noticed that often i lose my cars control.Without a reason,communication between transmiter-receiver stops for some seconds and the car is uncontrolable,without steering,throttle or brakes.This happens with both receivers i have for my two cars.I have to tell you that with other brands radios i don't have this problem and this is not caused by the distance as i remember that i noticed this issue on 5m ,on 25m or 50m.As you can understand is very risky to run my cars like this so im asking for some help.What can cause this issue and what can i do for this?
Born2Run is offline
Old 09-20-2007 | 10:03 AM
  #2395
tfrahm's Avatar
I'm no expert, but it sounds like a problem with binding the receivers to the transmitter...
For one thing - if the receiver is properly setup and bound, I can turn my transmitter OFF -- and the receiver will go into "fail safe"... I bind mine so that the fail safe position is neutral throttle and straight ahead steering...
tfrahm is offline
Old 09-20-2007 | 10:17 AM
  #2396
rocketron's Avatar
Are you using an LRP esc? Which servo's?
You may consider running a capacitor as the receiver can briefly lose power with the LRP esc's and also with some Servo's
rocketron is offline
Old 09-20-2007 | 10:34 AM
  #2397
Born2Run's Avatar
Im using a Nosram matrix evolution v.2007 esc (the same with LRP) and a Mamba max esc ,both with Futaba S3003 servos.As for the capacitor, you mean to use the SPM1600 on the receiver?
Born2Run is offline
Old 09-23-2007 | 12:45 PM
  #2398
mac853's Avatar
Could somebody tell me the real date to release the DX3R, because until now the sites didn't update yet, still shown like the Late October or 26th October (the last friday of the month) some kind of them.
Have they been delayed again?
mac853 is offline
Old 10-01-2007 | 05:59 PM
  #2399
doriftu's Avatar
hi,
Can different Spektrum Rx and module interchange? Meaning if I am using Pro module, can I use the standard (grey) Rx or the HRS RX?
has anyone tried that before?
doriftu is offline
Old 10-02-2007 | 08:18 AM
  #2400
Skitee's Avatar
Doriftu, the Pro Module will work the SR3000 (Grey Receiver) but it will not work with the HRS Receiver
Skitee is offline
