Spektrum
#886
Originally posted by JRX-S Bill
Thanks PitCrew. But, I have new information to add...
I emailed Spektrum last night. Their response when I got home was send the system back. Didn't see that until just now!
OK, but...
During the day, I had called Spektrum tech (at Horizon) and was told not to send it back. That I should install a cap on my QC2 and that would handle the issue with the erratic operation of my new KO 2343 servo.
Was advised that adding the cap to the Spektrum receiver only related to the original units made for the M8, not the KO Helios version as I have.
This evening, I installed the cap (Novak 4700uF) on my QC2; but, there was no improvement. The KO 2343 servo that I got yesterday is totally erratic when receiving steering inputs; and, the lights on my Spektrum receiver and transponder go off and one; except for when I move the wheel really slowly.
Now, I am thoroughly confused about what to do...
OK, but...
#887
Originally posted by Yeti35
Hey Bill, dump the QC2 and get a GTX. I have had no problems runnin Spektrum with my Novak ESC's. I have it working with GTX, GT7 and a C2. I know from all I have read about this issue I will never get one of those LRP ESC's while using Spektrum.
just to make work with the Spectrum that should have been re-called
#888
Originally posted by dawgmeat
Dump my Q2 that works
#889
It was my understanding that those ESC's don't put out enough power for the receiver to run the servo, hence why you need to install the cap to get it to work. Everything I read thus far about this issue is related to that speed control and certain servos. If it were me I would be on LRP rather the Spektrum, but this is just my opinion.
I run a Q2 and an Airtronics digital servo. I have had absolutly zero problems with the unit. Maybe the difference is that I run the LRP World's kit on the ESC!!
#890
OK, but...
OK, but...
MOSFET's in the ESC's open and close at specific intervals. The cap has to be designed accept power in the same interval the the MOSFET open's and closes. If the MOSFET is open when the cap is closed, the cap will not store any power and it will not do anything to help your problem. You need a cap that will work with the LRP MOSFET's. Or, to make it easier to understand, you need a cap that will accept and store power when the MOSFET releases it!!
Your best choice is to run the LRP World's Kit. Your problem will be solved!
#891
Trying to figure out if your being serious ? A cap charges when power is input to it. You really think novak or lrp design and manufacture their own caps........ What you just said makes absolutly no sense
#892
#893
A cap is a device consisting of 2 or more conductive plates seperated from one another by a dielectric nonconductor such as glass , mica , plastic , or dry air , used for storing an electric charge. Now tell me what component allows a cap to open or close at a specific or any given time for that matter ?
#894
Look at the Novak website where thyey offer 3-4 different caps. All the caps they offer are to be used with specific Novak ESC's. They, the manufacture call this out in bold, red type. They say do not use this cap with any other ESC than those listed!!
Novak says that not all their caps will work with all their ESC's. So what makes you think that any Novak cap will work with an LRP ESC????
#895
#896
Yes given a caps rating or size.... If you install a cap that is too small it will not work. We are not using the cap for the speedo....... We are simply storing power for the reciever/servo to utilize when the bec doesnt produce enough. 4700mf is plenty for this application. I am not looking to argue i am willing to learn , but the info needs to be correct.
#898
Originally posted by koabich
I am 100% serious. My terminology may not be 100% correct but caps are designed to work within a certain range. If the MOSFET's in the ESC do not operate within that range, the cap will not be as effective as the correct one or will not offer anything at all. Even on the Novak website you will see that, vist the LRP website as well. All caps are not the same. Not all caps will work with all ESC's.
what may make a difference is the material the cap is made of and the size. with these 2 differences, the transition time between when the extra power is needed by the receiver and servo may make the cap not very effective. think of it like this if it take one second to charge the cap, but the receiver and servo combo needs the extra juice every .5 seconds then the cap is not effective. at that point you have 2 options reduce the size of the cap or the makeup of the cap. so that it will charge faster. the problem with going smaller in terms of micro farads is that the amount of "charge" may not be enough to help the receiver\servo combination.
The important thing is to balance the power requirement with teh size and rating of the cap. not the make and model.
this is also true on the speedo thing.
#899
