Spektrum
Old 02-18-2005 | 08:29 PM
  #136
scmicromike's Avatar
Seems as though I was overlooked. I will repost and then clarify my question.
so we know that the cap works, but would a small reciever pack work as well. I am just a fan of making the weight on your car work for you. and I know the cap works for the problem but it dont weigh that much and it takes up a lot of space. on the other hand, I have a car that is under weight and I use weights to make up for this. If I am not mistaken dont 12 scale and pan cars make small reciever packs to act as "working weight". But this only works if it cures the problem.
WILL THE SMALL RECIEVER PACK CURE THE PROBLEM? thanks
scmicromike is offline
Old 02-18-2005 | 08:37 PM
  #137
scoobydo's Avatar
Maybe, it would have to be tested.
The plus with the cap is that you get more punch on your car when attached to your esc.
So there is a plus for having it even with the space issue.
A battery pack would just add power going to your reciever and would have no positives other than curing the so called problem and adding weight.
I would rather add weight and have the punch.
scoobydo is offline
Old 02-18-2005 | 08:39 PM
  #138
would have to say yes. just for grins in went down and plugged in a reciever pack from a nitro car and it worked.
vanguard is offline
Old 02-18-2005 | 08:46 PM
  #139
rovic's Avatar
advantages of have a reciever pack is you have full power to speedo & servos when you pack is low on voltage and also the servos and speedos dont drain from the pack. main reason 12scale guys use reciever packs...
cap on the speedo, doesnt benefit the reciever.
rovic is offline
Old 02-18-2005 | 10:05 PM
  #140
scoobydo's Avatar
I never said it benifited the reciever.
However the main reason 12th guys use it is because they still run 5 minute mains and they only have 4 cells.
The race like 7-8 minute mains in Japan with 6 cell I heard.
I hardly think you would have an issue with low voltage on your reciever and servo with 6 cell and 5 min mains.
Thats why I would rather have the punch.
scoobydo is offline
Old 02-18-2005 | 10:15 PM
  #141
wow 5 minutes in 12th scale, were getting ripped off, they make us run 8 minutes with 4 cells up here. whats up with that.
vanguard is offline
Old 02-18-2005 | 10:27 PM
  #142
Soviet's Avatar
You mean you DON'T like more track time?
Here at Debbies in Virginia Beach, VA, we run 19T 8-min main 1/12th scale. THe cars are plenty fast enough...however the added time makes for a FAR more interesting race.
Personally...I think ALL forms of electric racing should go to 8 mins. Sure...running ballistic for 5 mins can be fun...but it's more of a race the longer it is. Besides, I'd like to think we have larger capacity cells so we can run longer...not just gear our cars until they burst into flames.
-Soviet
Soviet is offline
Old 02-18-2005 | 10:30 PM
  #143
N4S ....PM
Joe B is offline
Old 02-19-2005 | 07:24 AM
  #144
I've just tested Pit Crew's solution with the cap:
IT WORKS Great!!!
I'm wondering something:
I got a personal transponder, in the manual, it is said to plug it AUX, so I plug the cap in BAT/TEL. This way it works, but when I Bind the system the receiver's led doesn't flashes green, but it works. AND when I plug the personal transponder in BAT/TEL and the cap in AUX, then I bind the system, the receiver's led flashes green (as it is said in the manual).
So my question is:
Will my personal transponder work if I plug it in BAT/TEL (because in the manual they said to plug it in AUX)???
Thanks a lot Pit Crew.
Hugo is offline
Old 02-19-2005 | 10:09 AM
  #145
Yes, either is fine to power the transponder.
thrust is offline
Old 02-19-2005 | 10:23 AM
  #146
Thanks for the answer Thrust.
Hugo is offline
Old 02-19-2005 | 11:53 AM
  #147
Speedo's Avatar
Sent the following email to Horizon/Spektrum
I picked up my spektrum unit last weekend. I only ran it once, but was hoping to use it during the coming weekends. Now I am hearing lots of reports of a laggy response time. People who were at the Snowbirds are reporting that pro drivers were taking it out of their cars and telling others to do the same because the response time was noticeably slower than with standard radio equipment. Appartently, even the Horizon rep that was there was saying "use it at your own risk" and blaming the slow response on the fluorescent lighting. Problem is, I only race indoor on carpet, and almost all carpet tracks have fluorescent lighting. I heard about the problems found with the units before the Cleveland race, but I also heard that they had been fixed, which is why I went ahead and bought my Spektrum unit. Now that I'm hearing all these reports that they are still bad, I'm very nervous. Like I said, I only ran it in the car once, and was more concerned at the time with the new chassis I was trying out. Next time I run it, I'll be paying close attention to the response time, and may even put my standard radio equipment back in to see if I notice a difference. If in fact there is a problem, as it seems there is, what are you doing to fix it? Will us racers who have already purchased the units be able to send them in to have them fixed?
And received this reply:
Thanks for your email. We have not heard anything about any trouble at Snowbirds. When the unit was in its first stages of testing, they did run across an issue with response time, but that issue was resolved long before actual production of this equipment had started. The equipment you have should work just fine. If you do run into any issue with it, please feel free to contact us at 1-877-504-0233, and we would be more than happy to discuss it with you. Thanks again for your email.
Speedo is offline
Old 02-19-2005 | 03:29 PM
  #148
Darkseid's Avatar
Regional Moderator
They hadn't "heard anything about any trouble at Snowbirds"???
EVERYONE has heard about the Spectrum's problems at Snowbirds.
I don't know which would be worse, if they are lying....or <gasp>...if they are so disconnected with whats going on that they're actually telling the truth! Yikes!!!
Darkseid is offline
Old 02-19-2005 | 04:17 PM
  #149
Formula1fan's Avatar
This thing is TRASH! save your shelf the headache and DO NOT BUY ONE
Formula1fan is offline
Old 02-19-2005 | 04:48 PM
  #150
ChrisP's Avatar
Care to validate that statement with some informationinstead of just an inflammatory comment?
ChrisP is offline
