Xray NT1
#1487
barely used those features on my offroad . thanks fellas for those tips! as of now i am building the kit with a laptop right next to me for reference and 3hobby.net open for tips hehecheers!
#1488
Answer: a good choice would be an engine like the OS TG. But if you are looking for an engine that is cabable of winning races, go with any of the Novarossi engines, like the NS12.
#1490
#1491
#1492
I think he meant the other tool : ---> to hold the clutch bell
http://www.serpent.com/product/802514/
#1493
#1494
Hallo Sebastian,
Glückwunsch, tolles ergebniss
I checked your set-sheet. U cut your tires with (left-right) 2 mm split. How was it after final. can you give us some diameters after race.
I saw your front track width is very narow. how was you off power steering. Did you get more off power steering with this setting
thnx
thnx
Thanks for the gratulation
#1495
Hey, where is everybody ??
Today I changed the diff seal. It was leaking.......... and I find out the original xray diff seal only last 1 time. The second time of use will be out of shape ..... shucks.
So I replace it with Hobao Hyper8 diff seal. It's slightly thicker and smaller diameter. I have to use special technique to install it. Roll it up ( from bottom to the seal location ) and tigthen the four screws in criss-cross manner.
Now it's perfectly sealed !!
#1498
#1499
#1500
I cant really answer that since this is my frst serious nitro car ( I had a 710 that i played with a little and it had a max masimo fantini) .The motor is more than enough for club racing ,I plan on using the 353 for big events and really big tracks.tuned and geared properly the practice motor is fast.
18Likes
